Ana içeriğe geç
Azpen A701 Motherboard Replacement
Neye ihtiyacın var
  1. Azpen A701 Motherboard Replacement, General Disassembly Prerequisite Guide: adım 1, 1 resimden 1.
    • Remove the two 2cm screws on the bottom using the PH0 Phillips head screw driver.
  2. Azpen A701 Motherboard Replacement: adım 2, 2 resimden 1. Azpen A701 Motherboard Replacement: adım 2, 2 resimden 2.
    • Pry open back piece with plastic spudger.
    • Remove the back piece of the device.
    • The back panel may be difficult to pry off, use gentle force.
  3. Azpen A701 Motherboard Replacement: adım 3, 1 resimden 1.
    • Disconnect speaker (which is attached by black and red wires) from back piece using plastic spudger.
  4. Azpen A701 Motherboard Replacement: adım 4, 1 resimden 1.
    • Gently pry the battery off of the device with the plastic spudger.
    • There is a large amount of glue holding the battery to the device.
    • Do not puncture the battery with the plastic spudger.
  5. Azpen A701 Motherboard Replacement, Motherboard: adım 5, 3 resimden 1. Azpen A701 Motherboard Replacement, Motherboard: adım 5, 3 resimden 2. Azpen A701 Motherboard Replacement, Motherboard: adım 5, 3 resimden 3.
    • Remove all three ZIF cables connected to the motherboard (the blue, angled piece) by lifting the gray flap with your finger or a plastic spudger and gently removing the cable.
  6. Azpen A701 Motherboard Replacement: adım 6, 3 resimden 1. Azpen A701 Motherboard Replacement: adım 6, 3 resimden 2. Azpen A701 Motherboard Replacement: adım 6, 3 resimden 3.
    • Remove the three 2cm screws at the bottom using the Phillips PH00 screwdriver head.
  7. Azpen A701 Motherboard Replacement: adım 7, 1 resimden 1.
    • Gently peel off the orange sticker with the gray wire connected to the upper corner of the device. This is the antenna.
  8. Azpen A701 Motherboard Replacement: adım 8, 1 resimden 1.
    • Remove solder connecting the battery to the motherboard using the soldering kit.
    • Place battery aside.
    • For more information on soldering, refer to iFixit's Soldering Guide.
  9. Azpen A701 Motherboard Replacement: adım 9, 1 resimden 1.
    • Remove solder connecting the speaker wires to the motherboard.
    • Set speaker aside.
  10. Azpen A701 Motherboard Replacement: adım 10, 1 resimden 1.
    • Remove solder connection the gray antenna wire to the motherboard.
    • Set antenna aside.
  11. Azpen A701 Motherboard Replacement: adım 11, 1 resimden 1.
    • Gently remove motherboard from device.
  12. Azpen A701 Motherboard Replacement: adım 12, 1 resimden 1.
    • Insert new motherboard.
    • Replace all three 2cm screws at the bottom of the motherboard.
Sonuç
Michael
568 İtibar
4 adet Kılavuz yazıldı
Ekip
Colorado Springs, Team 2-1, Panko Spring 2015 Colorado Springs, Team 2-1, Panko Spring 2015 üyesi
UCCS-PANKO-S15S2G1
3 Üyeler
12 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 308
