Ana içeriğe geç
Azpen A720 Battery Replacement
Neye ihtiyacın var
    1. Azpen A720 Battery Replacement, Back Cover: adım 1, 2 resimden 1. Azpen A720 Battery Replacement, Back Cover: adım 1, 2 resimden 2.
      • Use a Phillips #00 screwdriver to remove the two 4mm screws found on the top edge of the tablet near the power button.
      FixBot'a Sor
      Yorum Ekle
    2. Azpen A720 Battery Replacement: adım 2, 3 resimden 1. Azpen A720 Battery Replacement: adım 2, 3 resimden 2. Azpen A720 Battery Replacement: adım 2, 3 resimden 3.
      • Use the plastic opening tool to pry the white back from the silver frame. Start near the micro SD slot.
      • Slide the plastic opening tool around the perimeter of the casing until the back is disconnected.
      FixBot'a Sor
      Yorum Ekle
    3. Azpen A720 Battery Replacement: adım 3, 1 resimden 1.
      • Remove the rear casing.
      FixBot'a Sor
      Yorum Ekle
    1. Azpen A720 Battery Replacement, Battery: adım 4, 1 resimden 1.
      • Locate the batteries' connection points.
      FixBot'a Sor
      Yorum Ekle
    2. Azpen A720 Battery Replacement: adım 5, 1 resimden 1.
      Bu adımda kullanılan alet:
      • A soldering iron can reach 600˚ F, which will cause serious burns. Learn how to solder properly here. Using tweezers to hold the wires will reduce the risk of burns.
      • Use a soldering iron to melt the connections which attach the battery to the motherboard.
      • Disconnect the red and black wires from the motherboard.
      FixBot'a Sor
      Yorum Ekle
    3. Azpen A720 Battery Replacement: adım 6, 2 resimden 1. Azpen A720 Battery Replacement: adım 6, 2 resimden 2.
      • Peel the black sticker off the battery to disconnect the wifi antennae.
      FixBot'a Sor
      Yorum Ekle
    4. Azpen A720 Battery Replacement: adım 7, 3 resimden 1. Azpen A720 Battery Replacement: adım 7, 3 resimden 2. Azpen A720 Battery Replacement: adım 7, 3 resimden 3.
      • Slide the spudger between the battery and the metal backing. Move the spudger back and forth in a sawing motion to break the adhesive seal between the battery and the backing.
      • When the spudger is underneath the battery avoid prying. A prying motion could damage the battery.
      FixBot'a Sor
      Yorum Ekle
    5. Azpen A720 Battery Replacement: adım 8, 2 resimden 1. Azpen A720 Battery Replacement: adım 8, 2 resimden 2.
      • Remove the old battery and replace it with the new battery.
      FixBot'a Sor
      Yorum Ekle
Bitiş Çizgisi
Bir başkası bu kılavuzu tamamladı.
Ben
280 İtibar
2 adet Kılavuz yazıldı
Ekip
Michigan Tech, Team 1-3, Lauer Spring 2015 Michigan Tech, Team 1-3, Lauer Spring 2015 üyesi
MTU-LAUER-S15S1G3
2 Üyeler
5 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 21
Her zaman: 2,628
