Ana içeriğe geç
Azpen A720 Battery Replacement
Neye ihtiyacın var
  1. Azpen A720 Battery Replacement, Back Cover: adım 1, 2 resimden 1. Azpen A720 Battery Replacement, Back Cover: adım 1, 2 resimden 2.
    • Use a Phillips #00 screwdriver to remove the two 4mm screws found on the top edge of the tablet near the power button.
  2. Azpen A720 Battery Replacement: adım 2, 3 resimden 1. Azpen A720 Battery Replacement: adım 2, 3 resimden 2. Azpen A720 Battery Replacement: adım 2, 3 resimden 3.
    • Use the plastic opening tool to pry the white back from the silver frame. Start near the micro SD slot.
    • Slide the plastic opening tool around the perimeter of the casing until the back is disconnected.
  3. Azpen A720 Battery Replacement: adım 3, 1 resimden 1.
    • Remove the rear casing.
  4. Azpen A720 Battery Replacement, Battery: adım 4, 1 resimden 1.
    • Locate the batteries' connection points.
  5. Azpen A720 Battery Replacement: adım 5, 1 resimden 1.
    Bu adımda kullanılan alet:
    • A soldering iron can reach 600˚ F, which will cause serious burns. Learn how to solder properly here. Using tweezers to hold the wires will reduce the risk of burns.
    • Use a soldering iron to melt the connections which attach the battery to the motherboard.
    • Disconnect the red and black wires from the motherboard.
  6. Azpen A720 Battery Replacement: adım 6, 2 resimden 1. Azpen A720 Battery Replacement: adım 6, 2 resimden 2.
    • Peel the black sticker off the battery to disconnect the wifi antennae.
  7. Azpen A720 Battery Replacement: adım 7, 3 resimden 1. Azpen A720 Battery Replacement: adım 7, 3 resimden 2. Azpen A720 Battery Replacement: adım 7, 3 resimden 3.
    • Slide the spudger between the battery and the metal backing. Move the spudger back and forth in a sawing motion to break the adhesive seal between the battery and the backing.
    • When the spudger is underneath the battery avoid prying. A prying motion could damage the battery.
  8. Azpen A720 Battery Replacement: adım 8, 2 resimden 1. Azpen A720 Battery Replacement: adım 8, 2 resimden 2.
    • Remove the old battery and replace it with the new battery.
Bitiş Çizgisi
Bir başkası bu kılavuzu tamamladı.
Ben
280 İtibar
2 adet Kılavuz yazıldı
Ekip
Michigan Tech, Team 1-3, Lauer Spring 2015 Michigan Tech, Team 1-3, Lauer Spring 2015 üyesi
MTU-LAUER-S15S1G3
2 Üyeler
5 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 11
Son 30 gün: 37
Her zaman: 2,529
