Ana içeriğe geç
Azpen A720 Speaker Replacement
Neye ihtiyacın var
  1. Azpen A720 Speaker Replacement, Back Cover: adım 1, 2 resimden 1. Azpen A720 Speaker Replacement, Back Cover: adım 1, 2 resimden 2.
    • Use a Phillips #00 screwdriver to remove the two 4mm screws found on the top edge of the tablet near the power button.
  2. Azpen A720 Speaker Replacement: adım 2, 3 resimden 1. Azpen A720 Speaker Replacement: adım 2, 3 resimden 2. Azpen A720 Speaker Replacement: adım 2, 3 resimden 3.
    • Use the plastic opening tool to pry the white back from the silver frame. Start near the micro SD slot.
    • Slide the plastic opening tool around the perimeter of the casing until the back is disconnected.
  3. Azpen A720 Speaker Replacement: adım 3, 1 resimden 1.
    • Remove the rear casing.
  4. Azpen A720 Speaker Replacement, Speaker: adım 4, 1 resimden 1.
    • The speaker is a black oval located in the corner next to the battery.
  5. Azpen A720 Speaker Replacement: adım 5, 1 resimden 1.
    • Use a soldering iron to desolder the connections between the black and red speaker wires and the motherboard.
    • Remember which lead the black and red wires connect to on the motherboard.
    • Caution: The soldering iron gets very hot; be careful not to touch the tip and burn yourself. To learn to solder, click here.
  6. Azpen A720 Speaker Replacement: adım 6, 1 resimden 1.
    • Remove the speaker from the tablet.
Sonuç
Anna
353 İtibar
3 adet Kılavuz yazıldı
Ekip
Michigan Tech, Team 1-3, Lauer Spring 2015 Michigan Tech, Team 1-3, Lauer Spring 2015 üyesi
MTU-LAUER-S15S1G3
2 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 4
Son 30 gün: 7
Her zaman: 242
