Ana içeriğe geç
Azpen A740 Battery Replacement
Neye ihtiyacın var
  1. Azpen A740 Battery Replacement, Back Panel: adım 1, 1 resimden 1.
    • Use the plastic opening tool or black spudger tool to lift the back panel off the tablet.
  2. Azpen A740 Battery Replacement, Battery: adım 2, 2 resimden 1. Azpen A740 Battery Replacement, Battery: adım 2, 2 resimden 2.
    • Use the set of plastic opening tools to separate the inner backing from the electronics.
    • Use the Phillips screwdriver to remove the 3.8 mm screws, holding the inner backing of Azpen A740 Tablet.
  3. Azpen A740 Battery Replacement: adım 3, 1 resimden 1.
    • Disconnect the black, red, and grey wires leading to the battery from the motherboard using a soldering iron.
    • In order to desolder these connections follow the instructions on IFixit's How to Solder and Desolder Connections
  4. Azpen A740 Battery Replacement: adım 4, 2 resimden 1. Azpen A740 Battery Replacement: adım 4, 2 resimden 2.
    • Remove the black tape that is holding the battery in place.
  5. Azpen A740 Battery Replacement: adım 5, 1 resimden 1.
    • Remove the battery from the case using the blue prying or black spudger.
    • As you remove the battery it may be difficult to remove. Take your time to remove it carefully and try to avoid bending it.
Sonuç
Maile Sinclair
228 İtibar
2 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 4-5, Brown Winter 2015 USF Tampa, Team 4-5, Brown Winter 2015 üyesi
USFT-BROWN-W15S4G5
3 Üyeler
12 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 7
Son 30 gün: 11
Her zaman: 1,596
