Ana içeriğe geç
Azpen A909 Battery Replacement
Neye ihtiyacın var
    1. Azpen A909 Battery Replacement, Back Cover: adım 1, 1 resimden 1.
      • Begin by unscrewing the two 1.4 mm diameter Phillips #00 head screws at the top of the device.
      FixBot'a Sor
      Yorum Ekle
    2. Azpen A909 Battery Replacement: adım 2, 1 resimden 1.
      • Next, gently pry the cover off with a plastic opening tool or a similar instrument by loosening all of the anchoring points. Two of the anchoring points are circled in the image. Avoid excessive bending or pivoting, since doing so may break the anchoring points.
      FixBot'a Sor
      Yorum Ekle
    3. Azpen A909 Battery Replacement: adım 3, 1 resimden 1.
      • After prying open all of the anchoring points, the cover will lift off of the tablet.
      • To replace the cover, simply snap it back in place and re-insert the two screws. Because the speaker is not fully fixed to the interior of the tablet, make sure that it is in the position that will allow it to fit inside the speaker mounting on the cover.
      FixBot'a Sor
      Yorum Ekle
    1. Azpen A909 Battery Replacement, Battery: adım 4, 2 resimden 1. Azpen A909 Battery Replacement, Battery: adım 4, 2 resimden 2.
      • Remove the tape located at the end of the battery carefully
      • Do not rip the tape off too fast, as you could damage the red and black wires connecting the battery to the device
      FixBot'a Sor
      Yorum Ekle
    2. Azpen A909 Battery Replacement: adım 5, 1 resimden 1.
      • Using a plastic opening tool, gently pry the edges battery off of the backside of the touchscreen display. Start at the end of the battery opposite the connecting wires.
      • Once the edges are free, slowly work inward with the opening tool until the battery is free. This may take some time, since copious amounts of adhesive were used to anchor the battery in place.
      • Be careful not to damage the wires connecting the battery to the circuit board or the touchscreen underneath the battery.
      FixBot'a Sor
      Yorum Ekle
    3. Azpen A909 Battery Replacement: adım 6, 1 resimden 1.
      • If you are new to soldering, it's a good idea to check out iFixit's soldering and desoldering guide.
      • Pick a connection point and place the soldering iron on top of the wick above the existing solder ball.
      • Hold the soldering iron in place until the solder melts into the wick.
      • Repeat the same procedure on the remaining connector.
      • Lift the old battery off of the touchscreen. Make sure that all the solder has been removed before pulling the wires away from the board. The wires should come free with little to no resistance.
      • When soldering the lead connections for the new battery, take special care not to solder the two connectors together.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Zachary Kroll
275 İtibar
1 Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 3-5, Duarte Spring 2015 UMass Dartmouth, Team 3-5, Duarte Spring 2015 üyesi
UMASSD-DUARTE-S15S3G5
3 Üyeler
12 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 8
Son 30 gün: 24
Her zaman: 1,142
