Ana içeriğe geç
BOSE SoundTouch 30 Power Supply Replacement
Neye ihtiyacın var
  1. BOSE SoundTouch 30 Power Supply Replacement, Base Plate: adım 1, 2 resimden 1. BOSE SoundTouch 30 Power Supply Replacement, Base Plate: adım 1, 2 resimden 2.
    • Remove the four 15.5 mm PH2 screws securing the base plate to the device.
  2. BOSE SoundTouch 30 Power Supply Replacement, Power Supply: adım 2, 1 resimden 1.
    • Remove the six 15.5mm PH2 screws securing the grille and rear panel to the device.
  3. BOSE SoundTouch 30 Power Supply Replacement: adım 3, 2 resimden 1. BOSE SoundTouch 30 Power Supply Replacement: adım 3, 2 resimden 2.
    • Remove the grille and rear panel by grabbing the corners and pulling upwards and outwards.
    • There is a small ribbon cable that connects the display assembly to the body of the device. Make sure to disconnect the cable before pulling the grille all the way off or else the cable could snap.
    Is there any way to replace or repair the display ribbon cable? I snapped it and now I have no display.
    Carol Rigdon - Yanıt
  4. BOSE SoundTouch 30 Power Supply Replacement: adım 4, 1 resimden 1.
    • Remove all four 15.5 mm PH2 screws holding the power supply down.
    • The power supply is identified by a green board with a large metal covering.
    I can buy the parts with you guys.
    Jaime Ojeda - Yanıt
  5. BOSE SoundTouch 30 Power Supply Replacement: adım 5, 2 resimden 1. BOSE SoundTouch 30 Power Supply Replacement: adım 5, 2 resimden 2.
    • Disconnect the three cables from the power supply by squeezing the white tabs if present and gently pulling.
    • Pick up the power supply and remove the fourth cable from the underside of the power supply.
    • Remove the power supply.
    actually there are four connections - one underneath at the top of the picture above
    Simon Ward - Yanıt
Sonuç
11 farklı kişi bu kılavuzu tamamladı.
Brennen Irey
1.197 İtibar
6 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S16-G2, Livingston Spring 2018 Cal Poly, Team S16-G2, Livingston Spring 2018 üyesi
CPSU-LIVINGSTON-S18S16G2
4 Üyeler
7 adet Kılavuz yazıldı
30Kılavuz Yorumları
where can we buy the [power supply unit, as i have messed mine by using 220v instead of 110v
Hitesh Gohill - Yanıt
Hello. Do you want to exchange power supplies?
Contact me please!
Tomás Rosales -
Hi. My name Josley from Brazil.
I need you Power supply module for bose soundtouch 30.
You can help me?
Josley Oliveira -
Hola donde puedo comprar el modulo SoundTouch 30 Power Supply.
Muchas gracias.
Isidro -
I have the opposite problem. Bought the 110v instead of the 220v and now I have to use a step down transformer. Wanna exchange power supplies?
tomas@familiarosales.cl
Tomás Rosales - Yanıt
where did you buy the power supply?
Ulises Peña -
Do you want to sell the Bose 110v powersupply
Steve -
Hi, are you still interested in a board with 220v? I need a board with 120v?
Yongjoo Chung -
how do I buy a new power unit?
William Painap - Yanıt
Hi William
Im Kevin from Sydney, Australia.
I’d like to buy a power supply module for SoundTouch 30 as well but I cannot find anywhere.
Please let me know if you got any good news.
Cheers!
Kev
Kevin Hoang -
I’m from Adelaide, Australia and would love to know where I can get a 220v power supply?
matt.newman11 - Yanıt
The part number of the 220V power supply is 354778-002S. I’ll check the BOSE service center here in the Philippines if they have stock. I’m also going to replace it because someone plug that US version to our 220V outlet.
andrewmosqueda - Yanıt
Hi!. I have two units don´t sound it!. The subwoofer and speakers are good, because I tested it!. Also, I did fabrica reset it and I configured again!. Do you know if that fault is about motherboard o power supply PCB?
Pachon Marcos - Yanıt
Hi, same problem… plugged a 110V unit into 220V outlet… need a new power supply… anything that will work, even if have to use a step-up transformer…
Akash Rampersad - Yanıt
I am also looking for the replacement power board, BOSE offered to ‘look’ at the unit but the price was 70% of a new Bose 30!
simon springate - Yanıt
I would like to thank Electronic Partners (www.electronic.partners) who not only repaired my power board at the component level but converted it to 240V. Works like a dream. Now I don’t have to junk a perfectly good sound system.
Hi,
My name is Isidro, where can we buy the part component BOSE SoundTouch 30 Power Supply
Isidro - Yanıt
Hi Tomas,
We bought our Soundtouch30 in the USA. We have moved to Portugal where they have 220V. Can we just change the power supply in order for it to work in Portugal?
giorgio94103 - Yanıt
Where can I buy the power supply board, I’m in USA?
ken.velazquez - Yanıt
Ich bräuchte ebenfalls das Netzteil(Modul). Kann mir jemand weiterhelfen?
Breadhunter - Yanıt
I think this is a power supply to replacement.
https://www.chinahao.com/product/5390386...
fabriziomalta - Yanıt
Hi, do you know if this spare part worked on a Bose sound touch 30?
Jurgen Vanhove -
I need a power supply for Bose soundtoich 30. If some one wants to buy let.me know
Juan Fredy Mamani Condori - Yanıt
Hi, I am interested in a 120V power supply for SoundTouch 30. Do you have one?
Yongjoo Chung -
Hi I have bose cinemate 120 system on that control console not coming display on display board
Let me know remedies
Rajesh Kumar - Yanıt
Does anyone have 220V power supply?
youlwill - Yanıt
Hi, I have a Bose SoundTouch 30 with 220V and would like to switch to 120V. Do you have a 120V power supply board?
Yongjoo Chung -
I have a Bose Soundtouch 30 series iii US version 110V and it was plugged into 220V wall outlet. I opened it up and saw 2 blown out transistors (maybe?) I could only read half of the components part number as the half of it was blown out.
F 1F11AA
FCD
7N60
Could anyone please tell me what is the complete part number so I can try to order them on digikey? Please?
Natskie - Yanıt
Where do I buy the110 power supply for the Bose 30
Steve - Yanıt
Hello My name is Emmanuel from Cameroon.
Please I need a Bose Soundtouch 30 power supply. Where can I get it please?
Emmanuel Mbah - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 18
Son 30 gün: 122
Her zaman: 11,488
