Ana içeriğe geç
Baby Taylor Guitar String Replacement
Neye ihtiyacın var
  1. Baby Taylor Guitar String Replacement, Guitar String Replacement: adım 1, 3 resimden 1. Baby Taylor Guitar String Replacement, Guitar String Replacement: adım 1, 3 resimden 2. Baby Taylor Guitar String Replacement, Guitar String Replacement: adım 1, 3 resimden 3.
    • Rotate the tuner of the string you want to replace in a clockwise direction until it's loose.
    • You can either do it by hand (First Picture) or you can use the guitar string winder (Second picture).
  2. Baby Taylor Guitar String Replacement: adım 2, 2 resimden 1. Baby Taylor Guitar String Replacement: adım 2, 2 resimden 2.
    • Grab a plier and pull out the bridge pin of the string you want to replace.
    • Make sure that you've completed step 1 first. The string has to be loose before doing this step.
  3. Baby Taylor Guitar String Replacement: adım 3, 3 resimden 1. Baby Taylor Guitar String Replacement: adım 3, 3 resimden 2. Baby Taylor Guitar String Replacement: adım 3, 3 resimden 3.
    • Take out the string from the bridge and the tuning pin.
    • You can now throw away the string. You will not be needing it anymore.
  4. Baby Taylor Guitar String Replacement: adım 4, 2 resimden 1. Baby Taylor Guitar String Replacement: adım 4, 2 resimden 2.
    • Grab the new string and place the end (ball-end) inside the bridge.
    • The ball-end of a string is the side of the string that has a ball shape. (Shown in picture 2)
  5. Baby Taylor Guitar String Replacement: adım 5, 2 resimden 1. Baby Taylor Guitar String Replacement: adım 5, 2 resimden 2.
    • Place the bridge pin inside the bridge in order to lock in the new string.
    • Lightly hammer down the bridge pin to keep it from detaching.
  6. Baby Taylor Guitar String Replacement: adım 6, 2 resimden 1. Baby Taylor Guitar String Replacement: adım 6, 2 resimden 2.
    • Cut the excess string with a plier.
    • Cut the string around 1.5 inches over the desired tuning pin. (Recommended by Taylor Guitars)
  7. Baby Taylor Guitar String Replacement: adım 7, 1 resimden 1.
    • Place the new string inside the tuning pinhole.
    • It is recommended to place a really small portion of the string inside the pinhole to keep it from ripping your guitar bag. (As shown in the picture)
  8. Baby Taylor Guitar String Replacement: adım 8, 3 resimden 1. Baby Taylor Guitar String Replacement: adım 8, 3 resimden 2. Baby Taylor Guitar String Replacement: adım 8, 3 resimden 3.
    • Rotate the tuners in a counter-clockwise direction to tighten the new string.
    • You can either tighten it by hand (First Picture) or you can use the guitar string winder (Second Picture).
  9. Baby Taylor Guitar String Replacement: adım 9, 1 resimden 1.
    • Make sure your string is in tune and strum away!
Sonuç
Most guitar strings de-tune after they’ve been recently replaced. Tune your strings every once in a while for a few days and the strings will stay in tune.
Mohamed Saleh
230 İtibar
1 Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 19
Her zaman: 544
