Ana içeriğe geç
Backbone One Direction Pad Replacement
Neye ihtiyacın var
  1. Backbone One Direction Pad Replacement, Unfasten the screws: adım 1, 1 resimden 1.
    • Use a Phillips screwdriver to remove the four 5.9 mm-long screws.
    FixBot'a Sor
    Yorum Ekle
  2. Backbone One Direction Pad Replacement, Rotate the upper cover: adım 2, 3 resimden 1. Backbone One Direction Pad Replacement, Rotate the upper cover: adım 2, 3 resimden 2. Backbone One Direction Pad Replacement, Rotate the upper cover: adım 2, 3 resimden 3.
    • Lift up the upper part of the controller.
    • Swing over the upper cover and place it on the controller case.
    • Take care that the interconnecting cable has no tension.
    FixBot'a Sor
    Yorum Ekle
  3. Backbone One Direction Pad Replacement, Remove the protective tape: adım 3, 3 resimden 1. Backbone One Direction Pad Replacement, Remove the protective tape: adım 3, 3 resimden 2. Backbone One Direction Pad Replacement, Remove the protective tape: adım 3, 3 resimden 3.
    Bu adımda kullanılan alet:
    • Use a pair of tweezers to remove the yellow protective tape which is placed over the interconnect cable connector.
    FixBot'a Sor
    Yorum Ekle
  4. Backbone One Direction Pad Replacement, Open the ZIF connector: adım 4, 2 resimden 1. Backbone One Direction Pad Replacement, Open the ZIF connector: adım 4, 2 resimden 2.
    • Use the tip of an opening pick to open the gray flap of the ZIF connector by pushing it upwards.
    FixBot'a Sor
    Yorum Ekle
  5. Backbone One Direction Pad Replacement, Disconnect the interconnect cable: adım 5, 2 resimden 1. Backbone One Direction Pad Replacement, Disconnect the interconnect cable: adım 5, 2 resimden 2.
    • Use your fingers to disconnect the interconnect cable from its connector.
    FixBot'a Sor
    Yorum Ekle
  6. Backbone One Direction Pad Replacement: adım 6, 2 resimden 1. Backbone One Direction Pad Replacement: adım 6, 2 resimden 2.
    • Remove the upper half of the left controller assembly.
    FixBot'a Sor
    Yorum Ekle
  7. Backbone One Direction Pad Replacement, Remove the screw: adım 7, 2 resimden 1. Backbone One Direction Pad Replacement, Remove the screw: adım 7, 2 resimden 2.
    • Use a Phillips screwdriver to remove the 5.9 mm-long screw which is securing the trigger.
    • The screw is difficult to reach. Insert the screwdriver at an angle of 45 degrees.
    FixBot'a Sor
    Yorum Ekle
  8. Backbone One Direction Pad Replacement, Remove the trigger: adım 8, 2 resimden 1. Backbone One Direction Pad Replacement, Remove the trigger: adım 8, 2 resimden 2.
    • Remove the left trigger.
    FixBot'a Sor
    Yorum Ekle
  9. Backbone One Direction Pad Replacement, Remove the bumper: adım 9, 2 resimden 1. Backbone One Direction Pad Replacement, Remove the bumper: adım 9, 2 resimden 2.
    • Use your fingers to remove the left bumper.
    FixBot'a Sor
    Yorum Ekle
  10. Backbone One Direction Pad Replacement, Remove the screws: adım 10, 1 resimden 1.
    • Use a Phillips screwdriver to remove the four 3.9 mm-long screws.
    FixBot'a Sor
    Yorum Ekle
  11. Backbone One Direction Pad Replacement, Remove the mainboard: adım 11, 2 resimden 1. Backbone One Direction Pad Replacement, Remove the mainboard: adım 11, 2 resimden 2.
    • Remove the mainboard.
    FixBot'a Sor
    Yorum Ekle
  12. Backbone One Direction Pad Replacement, Remove the direction pad: adım 12, 3 resimden 1. Backbone One Direction Pad Replacement, Remove the direction pad: adım 12, 3 resimden 2. Backbone One Direction Pad Replacement, Remove the direction pad: adım 12, 3 resimden 3.
    • Use a pair of blunt nose tweezers to remove the direction pad.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Repair didn’t go as planned? Ask our Answers community for help.
Adriana Zwink
67.710 İtibar
167 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
123 Üyeler
28.236 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 12
Son 30 gün: 91
Her zaman: 3,278
