Ana içeriğe geç
Backbone One Face Buttons Replacement
Neye ihtiyacın var
  1. Backbone One Face Buttons Replacement, Remove the screws: adım 1, 1 resimden 1.
    • Use a Phillips screwdriver to remove the four 5.9 mm-long screws.
    FixBot'a Sor
    Yorum Ekle
  2. Backbone One Face Buttons Replacement, Rotate the upper part: adım 2, 3 resimden 1. Backbone One Face Buttons Replacement, Rotate the upper part: adım 2, 3 resimden 2. Backbone One Face Buttons Replacement, Rotate the upper part: adım 2, 3 resimden 3.
    • Lift up the upper cover of the controller.
    • Swing the upper cover over and place it on the controller case.
    • Make sure that the interconnecting cable has no tension.
    FixBot'a Sor
    Yorum Ekle
  3. Backbone One Face Buttons Replacement, Remove the protective tape: adım 3, 3 resimden 1. Backbone One Face Buttons Replacement, Remove the protective tape: adım 3, 3 resimden 2. Backbone One Face Buttons Replacement, Remove the protective tape: adım 3, 3 resimden 3.
    Bu adımda kullanılan alet:
    • Use a pair of tweezers to remove the yellow protective tape which is placed over the interconnect cable and the connector.
    FixBot'a Sor
    Yorum Ekle
  4. Backbone One Face Buttons Replacement, Open the interconnect cable ZIF connector: adım 4, 3 resimden 1. Backbone One Face Buttons Replacement, Open the interconnect cable ZIF connector: adım 4, 3 resimden 2. Backbone One Face Buttons Replacement, Open the interconnect cable ZIF connector: adım 4, 3 resimden 3.
    • Use the tip of an opening pick to open the gray flap of the interconnect cable ZIF connector by pushing it upwards.
    FixBot'a Sor
    Yorum Ekle
  5. Backbone One Face Buttons Replacement, Disconnect the interconnect cable: adım 5, 2 resimden 1. Backbone One Face Buttons Replacement, Disconnect the interconnect cable: adım 5, 2 resimden 2.
    • Disconnect the cable by pulling it straight out the ZIF connector.
    FixBot'a Sor
    Yorum Ekle
  6. Backbone One Face Buttons Replacement, Disconnect the phone connector cables: adım 6, 3 resimden 1. Backbone One Face Buttons Replacement, Disconnect the phone connector cables: adım 6, 3 resimden 2. Backbone One Face Buttons Replacement, Disconnect the phone connector cables: adım 6, 3 resimden 3.
    • Use a pair of tweezers to disconnect the phone connector cables out from their sockets.
    FixBot'a Sor
    Yorum Ekle
  7. Backbone One Face Buttons Replacement, Separate the upper case: adım 7, 1 resimden 1.
    • Separate the the upper case of the left controller handle.
    FixBot'a Sor
    Yorum Ekle
  8. Backbone One Face Buttons Replacement, Remove the screws: adım 8, 1 resimden 1.
    • Use a Phillips screwdriver to remove the three 5.9 mm-long screws.
    FixBot'a Sor
    Yorum Ekle
  9. Backbone One Face Buttons Replacement, Remove the trigger: adım 9, 2 resimden 1. Backbone One Face Buttons Replacement, Remove the trigger: adım 9, 2 resimden 2.
    • Remove the trigger.
    FixBot'a Sor
    Yorum Ekle
  10. Backbone One Face Buttons Replacement, Remove the bumper: adım 10, 2 resimden 1. Backbone One Face Buttons Replacement, Remove the bumper: adım 10, 2 resimden 2.
    • Remove the bumper.
    FixBot'a Sor
    Yorum Ekle
  11. Backbone One Face Buttons Replacement, Remove the screws: adım 11, 1 resimden 1.
    • Use a Phillips screwdriver to remove the two 3.9 mm-long screws.
    FixBot'a Sor
    Yorum Ekle
  12. Backbone One Face Buttons Replacement, Remove the mainboard: adım 12, 3 resimden 1. Backbone One Face Buttons Replacement, Remove the mainboard: adım 12, 3 resimden 2. Backbone One Face Buttons Replacement, Remove the mainboard: adım 12, 3 resimden 3.
    • Remove the mainboard.
    FixBot'a Sor
    Yorum Ekle
  13. Backbone One Face Buttons Replacement, Remove the rubber cover: adım 13, 3 resimden 1. Backbone One Face Buttons Replacement, Remove the rubber cover: adım 13, 3 resimden 2. Backbone One Face Buttons Replacement, Remove the rubber cover: adım 13, 3 resimden 3.
    • Use a pair of blunt nose tweezers to remove the rubber cover which is placed over the face buttons.
    FixBot'a Sor
    Yorum Ekle
  14. Backbone One Face Buttons Replacement, Remove the face buttons: adım 14, 3 resimden 1. Backbone One Face Buttons Replacement, Remove the face buttons: adım 14, 3 resimden 2. Backbone One Face Buttons Replacement, Remove the face buttons: adım 14, 3 resimden 3.
    • Use a pair of tweezers to remove the face buttons.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Repair didn’t go as planned? Ask our Answers community for help.
Bir başkası bu kılavuzu tamamladı.
Adriana Zwink
67.365 İtibar
167 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
122 Üyeler
26.511 adet Kılavuz yazıldı
1Rehber Yorum
is there any way to do this without taking apart the entire controller?
Robert - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 14
Son 30 gün: 64
Her zaman: 3,446
