Ana içeriğe geç
Backbone One Right Trigger Replacement
Neye ihtiyacın var
  1. Backbone One Right Trigger Replacement, Remove the screws: adım 1, 1 resimden 1.
    • Use a Phillips screwdriver to remove the four 5.9 mm-long screws.
    FixBot'a Sor
    Yorum Ekle
  2. Backbone One Right Trigger Replacement, Rotate the upper part: adım 2, 3 resimden 1. Backbone One Right Trigger Replacement, Rotate the upper part: adım 2, 3 resimden 2. Backbone One Right Trigger Replacement, Rotate the upper part: adım 2, 3 resimden 3.
    • Lift up the upper cover of the controller.
    • Swing the upper cover over and place it on the controller case.
    • Make sure that the interconnecting cable has no tension.
    FixBot'a Sor
    Yorum Ekle
  3. Backbone One Right Trigger Replacement, Remove the protective tape: adım 3, 3 resimden 1. Backbone One Right Trigger Replacement, Remove the protective tape: adım 3, 3 resimden 2. Backbone One Right Trigger Replacement, Remove the protective tape: adım 3, 3 resimden 3.
    Bu adımda kullanılan alet:
    • Use a pair of tweezers to remove the yellow protective tape which is placed over the interconnect cable and the connector.
    FixBot'a Sor
    Yorum Ekle
  4. Backbone One Right Trigger Replacement, Open the interconnect cable ZIF connector: adım 4, 3 resimden 1. Backbone One Right Trigger Replacement, Open the interconnect cable ZIF connector: adım 4, 3 resimden 2. Backbone One Right Trigger Replacement, Open the interconnect cable ZIF connector: adım 4, 3 resimden 3.
    • Use the tip of an opening pick to open the gray flap of the interconnect cable ZIF connector by pushing it upwards.
    FixBot'a Sor
    Yorum Ekle
  5. Backbone One Right Trigger Replacement, Disconnect the interconnect cable: adım 5, 2 resimden 1. Backbone One Right Trigger Replacement, Disconnect the interconnect cable: adım 5, 2 resimden 2.
    • Disconnect the cable by pulling it straight out the ZIF connector.
    FixBot'a Sor
    Yorum Ekle
  6. Backbone One Right Trigger Replacement, Disconnect the phone connector cables: adım 6, 3 resimden 1. Backbone One Right Trigger Replacement, Disconnect the phone connector cables: adım 6, 3 resimden 2. Backbone One Right Trigger Replacement, Disconnect the phone connector cables: adım 6, 3 resimden 3.
    • Use a pair of tweezers to disconnect the phone connector cables out from their sockets.
    FixBot'a Sor
    Yorum Ekle
  7. Backbone One Right Trigger Replacement, Separate the upper case: adım 7, 1 resimden 1.
    • Separate the the upper case of the left controller handle.
    FixBot'a Sor
    Yorum Ekle
  8. Backbone One Right Trigger Replacement, Remove the screws: adım 8, 1 resimden 1.
    • Use a Phillips screwdriver to remove the three 5.9 mm-long screws.
    FixBot'a Sor
    Yorum Ekle
  9. Backbone One Right Trigger Replacement, Remove the trigger: adım 9, 2 resimden 1. Backbone One Right Trigger Replacement, Remove the trigger: adım 9, 2 resimden 2.
    • Remove the trigger.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Opening didn’t go as planned? Answers community for help.
Bir başkası bu kılavuzu tamamladı.
Adriana Zwink
67.702 İtibar
167 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
123 Üyeler
28.230 adet Kılavuz yazıldı
2Kılavuz Yorumları
where can I buy a right trigger replacement?
pelony felony - Yanıt Paylaş
Ricardo Gazo Rosario - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 9
Son 30 gün: 55
Her zaman: 1,829
