Ana içeriğe geç
Baitcast Fishing Reel Pawl Replacement
Bradley Turner
Bradley Turner ve 5 diğer katkıda bulunanlar
En son March 7, 2024 tarihinde güncellendi
30 dakika
Orta
A broken pawl, where unnatural grooves have been made, can cause the line to get caught and start spooling on the side. This is a guide on how to easily replace a baitcasting fishing reel's pawl so you can get right back to fishing.
Before starting, make sure you have a spare pawl for the reel's specific brand on hand to make the process smoother as most pawls are not interchangeable.
Neye ihtiyacın var
iFixit bu bağlantılar üzerinden satın aldığınızda komisyon kazanır.
  1. Baitcast Fishing Reel Pawl Replacement, Pawl: adım 1, 2 resimden 1. Baitcast Fishing Reel Pawl Replacement, Pawl: adım 1, 2 resimden 2.
    • Remove the non-reel side plate by pulling on the small latch on the side with the reel.
  2. Baitcast Fishing Reel Pawl Replacement: adım 2, 2 resimden 1. Baitcast Fishing Reel Pawl Replacement: adım 2, 2 resimden 2.
    • Grab the end of the rod connected to the line spool and pull it directly out of its frame.
  3. Baitcast Fishing Reel Pawl Replacement: adım 3, 2 resimden 1. Baitcast Fishing Reel Pawl Replacement: adım 3, 2 resimden 2.
    • Loosen the single bolt with a 17 mm wrench.
    • Use a Phillips #0 screwdriver to unscrew the single screw that attaches the reel to the reel side plate.
    • Lift off the reel.
  4. Baitcast Fishing Reel Pawl Replacement: adım 4, 2 resimden 1. Baitcast Fishing Reel Pawl Replacement: adım 4, 2 resimden 2.
    • Use a Phillips #0 screwdriver to remove the three screws on the reel side plate.
  5. Baitcast Fishing Reel Pawl Replacement: adım 5, 3 resimden 1. Baitcast Fishing Reel Pawl Replacement: adım 5, 3 resimden 2. Baitcast Fishing Reel Pawl Replacement: adım 5, 3 resimden 3.
    • Unscrew the drag apparatus by hand and remove the reel side plate.
  6. Baitcast Fishing Reel Pawl Replacement: adım 6, 1 resimden 1.
    • Use a Phillips #0 screwdriver to remove the single screw that attaches the grill to the body of the reel.
  7. Baitcast Fishing Reel Pawl Replacement: adım 7, 2 resimden 1. Baitcast Fishing Reel Pawl Replacement: adım 7, 2 resimden 2.
    Bu adımda kullanılan alet:
    Flathead 3/32" or 2.5 mm Screwdriver
    $5.49
    • Use a 2.5 mm flathead screwdriver to remove the pawl cap on the body of the reel.
  8. Baitcast Fishing Reel Pawl Replacement: adım 8, 2 resimden 1. Baitcast Fishing Reel Pawl Replacement: adım 8, 2 resimden 2.
    • Carefully remove the damaged pawl and washer from the line guide apparatus.
  9. Baitcast Fishing Reel Pawl Replacement: adım 9, 1 resimden 1.
    • Clean the worm gear of any dirt or debris with Q-tips and paper towels.
  10. Baitcast Fishing Reel Pawl Replacement: adım 10, 1 resimden 1.
    • Insert the new pawl and previous washer back into the cap, and screw the cap back into place with a 2.5 mm flathead screwdriver.
  11. Baitcast Fishing Reel Pawl Replacement: adım 11, 1 resimden 1.
    • Use a Phillips #0 screwdriver to reattach the grill.
    • Place the spool back into the body of the reel.
  12. Baitcast Fishing Reel Pawl Replacement: adım 12, 1 resimden 1.
    • Use a Phillips #0 screwdriver to reinstall the three screws securing the reel side plate.
  13. Baitcast Fishing Reel Pawl Replacement: adım 13, 2 resimden 1. Baitcast Fishing Reel Pawl Replacement: adım 13, 2 resimden 2.
    • Pull the small latch and place the non-reel side plate back in its original position.
  14. Baitcast Fishing Reel Pawl Replacement: adım 14, 2 resimden 1. Baitcast Fishing Reel Pawl Replacement: adım 14, 2 resimden 2.
    • Screw the drag apparatus on with your hand until it clicks into position.
    • Reattach the reel by tightening the bolt with a 17 mm wrench, and replace the single screw on the side plate with a Phillips #0 screwdriver.
  15. Baitcast Fishing Reel Pawl Replacement: adım 15, 1 resimden 1.
    • Crank the reel for one minute to make sure the line guide moves back and forth freely without getting stuck on one side.
Sonuç
Happy fishing!
Bir başkası bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 5
Son 7 gün: 13
Son 30 gün: 33
Her zaman: 1,066
