Ana içeriğe geç
Basis B1 Band LED Screen Replacement
  1. Basis B1 Band LED Screen Replacement, Watch Strap: adım 1, 1 resimden 1.
    • Wedge a plastic opening tool between band contacts.
  2. Basis B1 Band LED Screen Replacement: adım 2, 1 resimden 1.
    • Push in plastic opening tool until the components click and pop out of the holder.
    • Repeat steps for other band.
  3. Basis B1 Band LED Screen Replacement, Back Plate: adım 3, 1 resimden 1.
    • Remove four 4mm screws using a PH000 screwdriver.
    • Remove back plate.
  4. Basis B1 Band LED Screen Replacement, Battery: adım 4, 1 resimden 1.
    • Use tweezers to remove elastomeric, or zebra, connector.
  5. Basis B1 Band LED Screen Replacement: adım 5, 2 resimden 1. Basis B1 Band LED Screen Replacement: adım 5, 2 resimden 2.
    • Use the flat end of the spudger to carefully lift the battery until adhesive seal is broken.
  6. Basis B1 Band LED Screen Replacement: adım 6, 1 resimden 1.
    • Use the pointy edge of the spudger tool to detach battery leads from the circuit board.
  7. Basis B1 Band LED Screen Replacement, LED Screen: adım 7, 2 resimden 1. Basis B1 Band LED Screen Replacement, LED Screen: adım 7, 2 resimden 2.
    • Use PH000 screw driver to remove two 6mm bracketed screws.
    • Remove bracket.
  8. Basis B1 Band LED Screen Replacement: adım 8, 1 resimden 1.
    • Use PH000 tool to remove two 4mm screws.
  9. Basis B1 Band LED Screen Replacement: adım 9, 1 resimden 1.
  10. Basis B1 Band LED Screen Replacement: adım 10, 1 resimden 1.
    • Use spudger tool to lift the clasp of LED connector strip and remove from watch case.
  11. Basis B1 Band LED Screen Replacement: adım 11, 1 resimden 1.
    • Use spudger tool to remove the LED screen from the watch case.
Sonuç
Kaitlyn Lee
518 İtibar
4 adet Kılavuz yazıldı
IUPUI, Team S6-G1, Baechle Fall 2017 IUPUI, Team S6-G1, Baechle Fall 2017 üyesi
IUPUI-BAECHLE-F17S6G1
4 Üyeler
0 Comments
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 4
Her zaman: 151
