Ana içeriğe geç
Beats Solo 3 Battery Replacement
Neye ihtiyacın var
  1. Beats Solo 3 Battery Replacement, Battery: adım 1, 2 resimden 1. Beats Solo 3 Battery Replacement, Battery: adım 1, 2 resimden 2.
    • Pry off the outside pane on the right side of the headphone with an opening tool.
  2. Beats Solo 3 Battery Replacement: adım 2, 1 resimden 1.
    • You should see your battery here. It will be square with yellow packaging.
    • Be sure not to pull on the wires that are connected to the outside panel. This may cause damage to your headphones.
  3. Beats Solo 3 Battery Replacement: adım 3, 2 resimden 1. Beats Solo 3 Battery Replacement: adım 3, 2 resimden 2.
    Bu adımda kullanılan alet:
    • Grasp the battery's small bundled connector, and pull gently to remove.
    • Carefully remove the top attachment from the headphones with tweezers or your fingers.
  4. Beats Solo 3 Battery Replacement: adım 4, 2 resimden 1. Beats Solo 3 Battery Replacement: adım 4, 2 resimden 2.
    • Use an opening tool or a nylon spudger to carefully remove the battery. Make sure you pry upward.
    • Do not bend or puncture the lithium-ion battery.
    • Once that is removed, make sure you peel off the sticker where the battery is placed if it stuck to the battery.
    • If it is, then place it back where it belongs in the headphones.
Sonuç
6 farklı kişi bu kılavuzu tamamladı.
4Kılavuz Yorumları
Where too buy battery?
GSD - Yanıt
Google . Internet
Mari Carmen Núñez -
Thank you! This worked great!
NYCGinkgo - Yanıt
Hello I have an issue where the battery is soldered on and only has two wires can anyone advise. My headphones are beats solo3
agustin rodiles - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 23
Son 7 gün: 120
Son 30 gün: 600
Her zaman: 17,970
