Ana içeriğe geç
Beats Solo 3 Motherboard Replacement
Neye ihtiyacın var
  1. Beats Solo 3 Motherboard Replacement, Motherboard: adım 1, 1 resimden 1.
    • Use an opening tool to open the headband at the color seam.
    • The audio board is located inside the "Left" ear cup.
  2. Beats Solo 3 Motherboard Replacement: adım 2, 2 resimden 1. Beats Solo 3 Motherboard Replacement: adım 2, 2 resimden 2.
    Bu adımda kullanılan alet:
    Satın Al
    • Use a pair of tweezers to carefully remove the yellow polyimide tape that is attached to the morherboard.
  3. Beats Solo 3 Motherboard Replacement: adım 3, 1 resimden 1.
    • There will be three bundled cables attached to the motherboard. Carefully pull them out of each prong.
    • Make sure to take note of which one belongs where for reassembly later.
  4. Beats Solo 3 Motherboard Replacement: adım 4, 1 resimden 1.
    • Use a Phillips #00 screwdriver to remove the four screws that hold the motherboard in place.
    • The cap on the outside of the headphones will fall off once the final screw is removed. Do not fear that something broke. Simply reattach during reassembly phase
  5. Beats Solo 3 Motherboard Replacement: adım 5, 1 resimden 1.
    • Finally, remove and replace the motherboard.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Jakub Karl
186 İtibar
1 Kılavuz yazıldı
Bir Yorum
no suena el altavoz izquierdo do los cascos en modo inalambrico
supongo que es placa base
?puede decirme donde puedo comprar placa base?
l1967e - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 5
Son 7 gün: 62
Son 30 gün: 326
Her zaman: 6,969
