Ana içeriğe geç
Beats Studio 2 Wireless Battery Replacement
Neye ihtiyacın var
  1. Beats Studio 2 Wireless Battery Replacement, Battery: adım 1, 2 resimden 1. Beats Studio 2 Wireless Battery Replacement, Battery: adım 1, 2 resimden 2.
    • Using a spudger, remove the panel circling the ‘b’ Beats logo on the right earphone by applying pressure upwards under the panel until it is removed.
    FixBot'a Sor
    Yorum Ekle
  2. Beats Studio 2 Wireless Battery Replacement: adım 2, 2 resimden 1. Beats Studio 2 Wireless Battery Replacement: adım 2, 2 resimden 2.
    • Remove the four screws securing the housing with a Phillips #00 screwdriver.
    FixBot'a Sor
    Yorum Ekle
  3. Beats Studio 2 Wireless Battery Replacement: adım 3, 1 resimden 1.
    • Use a spudger to release the clip in the seam under the silver “studio” label.
    • Remove the right side of the headband.
    FixBot'a Sor
    Yorum Ekle
  4. Beats Studio 2 Wireless Battery Replacement: adım 4, 1 resimden 1.
    • Gently remove the right earphone speaker from the headband by sliding the speaker downwards.
    FixBot'a Sor
    Yorum Ekle
  5. Beats Studio 2 Wireless Battery Replacement: adım 5, 3 resimden 1. Beats Studio 2 Wireless Battery Replacement: adım 5, 3 resimden 2. Beats Studio 2 Wireless Battery Replacement: adım 5, 3 resimden 3.
    • Use the pointed tip of a spudger to carefully push on each side of the connector to release it from the socket on the motherboard.
    • Be gentle with the connectors as they can break easily.
    • Don't use a metal spudger to remove a battery or any internal component. This is potentially dangerous as it could puncture the battery and cause a fire or worse.
    • Use a nylon spudger to remove the battery from the headphones.
    FixBot'a Sor
    Yorum Ekle
Sonuç
5 farklı kişi bu kılavuzu tamamladı.
Jack Wilson
581 İtibar
2 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 5-3, Ramos Spring 2023 UMass Dartmouth, Team 5-3, Ramos Spring 2023 üyesi
UMASSD-RAMOS-S23S5G3
3 Üyeler
8 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 10
Son 7 gün: 38
Son 30 gün: 186
Her zaman: 6,791
