Ana içeriğe geç
Beats Studio3 Wireless Hinge Replacement
Neye ihtiyacın var
  1. Beats Studio3 Wireless Hinge Replacement, Ear Pad: adım 1, 2 resimden 1. Beats Studio3 Wireless Hinge Replacement, Ear Pad: adım 1, 2 resimden 2.
    • Find the separation between the headset and ear cushion.
    • Use an opening tool to go underneath the separation site and split the pieces apart.
    FixBot'a Sor
    Yorum Ekle
  2. Beats Studio3 Wireless Hinge Replacement: adım 2, 3 resimden 1. Beats Studio3 Wireless Hinge Replacement: adım 2, 3 resimden 2. Beats Studio3 Wireless Hinge Replacement: adım 2, 3 resimden 3.
    • You can also use your hands to remove it completely.
    • Pulling it off can be challenging; make sure to apply enough pressure.
    FixBot'a Sor
    Yorum Ekle
  3. Beats Studio3 Wireless Hinge Replacement, Left Driver Assembly: adım 3, 2 resimden 1. Beats Studio3 Wireless Hinge Replacement, Left Driver Assembly: adım 3, 2 resimden 2.
    • Remove seven 3.6 mm screws holding the speaker assembly in place using a Phillips #0 screwdriver.
    • Make sure the screws aren't close to the speaker; due to it being a magnet, the screws could get stuck and damage the speaker.
    • Open the speaker by pulling the top layer of the speaker.
    FixBot'a Sor
    Yorum Ekle
  4. Beats Studio3 Wireless Hinge Replacement: adım 4, 3 resimden 1. Beats Studio3 Wireless Hinge Replacement: adım 4, 3 resimden 2. Beats Studio3 Wireless Hinge Replacement: adım 4, 3 resimden 3.
    • With a heat gun or hair dryer, heat the glue that is sticking the wires down until the glue softens.
    • Use a nylon spudger to remove the glue.
    • Pull on the wire to remove it while also removing the blue rubber band.
    FixBot'a Sor
    Yorum Ekle
  5. Beats Studio3 Wireless Hinge Replacement: adım 5, 3 resimden 1. Beats Studio3 Wireless Hinge Replacement: adım 5, 3 resimden 2. Beats Studio3 Wireless Hinge Replacement: adım 5, 3 resimden 3.
    • Using a soldering iron to remove the cables on the charger port.
    • For help with soldering, check out the How to Solder and Desolder Connections guide.
    • Remove the two wires connected in the middle of the speaker using a soldering iron.
    • Remove the speaker from the headset.
    FixBot'a Sor
    Yorum Ekle
  6. Beats Studio3 Wireless Hinge Replacement, Battery: adım 6, 2 resimden 1. Beats Studio3 Wireless Hinge Replacement, Battery: adım 6, 2 resimden 2.
    • Use a pointed nylon spudger to remove the center circular panel on the right side of your device.
    • Be gentle while removing this piece as it is glued on with adhesive.
    FixBot'a Sor
    Yorum Ekle
  7. Beats Studio3 Wireless Hinge Replacement: adım 7, 2 resimden 1. Beats Studio3 Wireless Hinge Replacement: adım 7, 2 resimden 2.
    • Remove the four 3.5 mm screws using a Phillips #0 screwdriver.
    FixBot'a Sor
    Yorum Ekle
  8. Beats Studio3 Wireless Hinge Replacement: adım 8, 3 resimden 1. Beats Studio3 Wireless Hinge Replacement: adım 8, 3 resimden 2. Beats Studio3 Wireless Hinge Replacement: adım 8, 3 resimden 3.
    • Using a pointed nylon spudger, remove the tab located on the inner part of the headband labeled "R."
    • Place the nylon spudger in between the side panels and push inward going from bottom to top to separate both sides of the panel.
    • The panel will pop open after separating.
    FixBot'a Sor
    Yorum Ekle
  9. Beats Studio3 Wireless Hinge Replacement: adım 9, 1 resimden 1.
    • Place the nylon spudger underneath the battery, push inward and separate the battery from the inside.
    • Never use sharp tools to pry batteries. Metal spudgers can puncture an unprotected battery, potentially causing a fire.
    FixBot'a Sor
    Yorum Ekle
  10. Beats Studio3 Wireless Hinge Replacement: adım 10, 2 resimden 1. Beats Studio3 Wireless Hinge Replacement: adım 10, 2 resimden 2.
    • Use a nylon spudger to lift up the glue sticking the wires down.
    • Use a nylon spudger to lift the connector to disconnect the battery.
    FixBot'a Sor
    Yorum Ekle
  11. Beats Studio3 Wireless Hinge Replacement, Hinge: adım 11, 3 resimden 1. Beats Studio3 Wireless Hinge Replacement, Hinge: adım 11, 3 resimden 2. Beats Studio3 Wireless Hinge Replacement, Hinge: adım 11, 3 resimden 3.
    • Pull the wire making sure that the blue rubber band is off.
    • Heat the glue holding the wires down with a hair dryer or heat gun until the glue softens.
    • Make sure not to overheat any device part, which could cause damage to the sound.
    • With a pointed nylon spudger, remove the glue.
    FixBot'a Sor
    Yorum Ekle
  12. Beats Studio3 Wireless Hinge Replacement: adım 12, 2 resimden 1. Beats Studio3 Wireless Hinge Replacement: adım 12, 2 resimden 2.
    FixBot'a Sor
    Yorum Ekle
  13. Beats Studio3 Wireless Hinge Replacement: adım 13, 3 resimden 1. Beats Studio3 Wireless Hinge Replacement: adım 13, 3 resimden 2. Beats Studio3 Wireless Hinge Replacement: adım 13, 3 resimden 3.
    • With a hair dryer or heating gun, heat the glue that is sticking the wires down.
    • Use a nylon spudger to remove the softened glue.
    • Remove the circular tape inside of the ear pad.
    FixBot'a Sor
    Yorum Ekle
  14. Beats Studio3 Wireless Hinge Replacement: adım 14, 2 resimden 1. Beats Studio3 Wireless Hinge Replacement: adım 14, 2 resimden 2.
    • Remove the single 3.5 mm screw with a Phillips #0 screwdriver.
    • Pull apart the top layer of the earpiece.
    FixBot'a Sor
    Yorum Ekle
  15. Beats Studio3 Wireless Hinge Replacement: adım 15, 2 resimden 1. Beats Studio3 Wireless Hinge Replacement: adım 15, 2 resimden 2.
    • Remove the tape holding the wires in place.
    • Pull the wires through the hole with your hand.
    FixBot'a Sor
    Yorum Ekle
  16. Beats Studio3 Wireless Hinge Replacement: adım 16, 1 resimden 1.
    • Bend the hinge and remove the two 3.5 mm screws with a Phillips #0 screwdriver.
    FixBot'a Sor
    Yorum Ekle
  17. Beats Studio3 Wireless Hinge Replacement: adım 17, 3 resimden 1. Beats Studio3 Wireless Hinge Replacement: adım 17, 3 resimden 2. Beats Studio3 Wireless Hinge Replacement: adım 17, 3 resimden 3.
    • Pull the hinge down.
    • Pull on the wires one at a time making sure you don't damage them.
    FixBot'a Sor
    Yorum Ekle
  18. Beats Studio3 Wireless Hinge Replacement: adım 18, 2 resimden 1. Beats Studio3 Wireless Hinge Replacement: adım 18, 2 resimden 2.
    Bu adımda kullanılan alet:
    • With tweezers, remove the pin located inside of the hinge.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Nayeli watts
543 İtibar
3 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 7-4, Ryckebusch Spring 2023 UMass Dartmouth, Team 7-4, Ryckebusch Spring 2023 üyesi
UMASSD-RYCKEBUSCH-S23S7G4
3 Üyeler
13 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 8
Son 7 gün: 64
Son 30 gün: 252
Her zaman: 10,884
