Ana içeriğe geç
Beats Studio3 Wireless Left Driver Assembly Replacement
Neye ihtiyacın var
  1. Beats Studio3 Wireless Left Driver Assembly Replacement, Ear Pad: adım 1, 2 resimden 1. Beats Studio3 Wireless Left Driver Assembly Replacement, Ear Pad: adım 1, 2 resimden 2.
    • Find the separation between the headset and ear cushion.
    • Use an opening tool to go underneath the separation site and split the pieces apart.
    FixBot'a Sor
    Yorum Ekle
  2. Beats Studio3 Wireless Left Driver Assembly Replacement: adım 2, 3 resimden 1. Beats Studio3 Wireless Left Driver Assembly Replacement: adım 2, 3 resimden 2. Beats Studio3 Wireless Left Driver Assembly Replacement: adım 2, 3 resimden 3.
    • You can also use your hands to remove it completely.
    • Pulling it off can be challenging; make sure to apply enough pressure.
    FixBot'a Sor
    Yorum Ekle
  3. Beats Studio3 Wireless Left Driver Assembly Replacement, Left Driver Assembly: adım 3, 2 resimden 1. Beats Studio3 Wireless Left Driver Assembly Replacement, Left Driver Assembly: adım 3, 2 resimden 2.
    • Remove seven 3.6 mm screws holding the speaker assembly in place using a Phillips #0 screwdriver.
    • Make sure the screws aren't close to the speaker; due to it being a magnet, the screws could get stuck and damage the speaker.
    • Open the speaker by pulling the top layer of the speaker.
    FixBot'a Sor
    Yorum Ekle
  4. Beats Studio3 Wireless Left Driver Assembly Replacement: adım 4, 3 resimden 1. Beats Studio3 Wireless Left Driver Assembly Replacement: adım 4, 3 resimden 2. Beats Studio3 Wireless Left Driver Assembly Replacement: adım 4, 3 resimden 3.
    • With a heat gun or hair dryer, heat the glue that is sticking the wires down until the glue softens.
    • Use a nylon spudger to remove the glue.
    • Pull on the wire to remove it while also removing the blue rubber band.
    FixBot'a Sor
    Yorum Ekle
  5. Beats Studio3 Wireless Left Driver Assembly Replacement: adım 5, 3 resimden 1. Beats Studio3 Wireless Left Driver Assembly Replacement: adım 5, 3 resimden 2. Beats Studio3 Wireless Left Driver Assembly Replacement: adım 5, 3 resimden 3.
    • Using a soldering iron to remove the cables on the charger port.
    • For help with soldering, check out the How to Solder and Desolder Connections guide.
    • Remove the two wires connected in the middle of the speaker using a soldering iron.
    • Remove the speaker from the headset.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Nayeli watts
543 İtibar
3 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 7-4, Ryckebusch Spring 2023 UMass Dartmouth, Team 7-4, Ryckebusch Spring 2023 üyesi
UMASSD-RYCKEBUSCH-S23S7G4
3 Üyeler
13 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 19
Son 30 gün: 62
Her zaman: 2,880
