Ana içeriğe geç
Beboncool Gamepad for Nintendo Switch Battery Replacement
Neye ihtiyacın var
  1. Beboncool Gamepad for Nintendo Switch Battery Replacement, Beboncool Nintendo Switch Gamepad Disassembly: adım 1, 3 resimden 1. Beboncool Gamepad for Nintendo Switch Battery Replacement, Beboncool Nintendo Switch Gamepad Disassembly: adım 1, 3 resimden 2. Beboncool Gamepad for Nintendo Switch Battery Replacement, Beboncool Nintendo Switch Gamepad Disassembly: adım 1, 3 resimden 3.
    • Use the plastic opening tool to remove the blue plastic grips from the sides of the controller.
  2. Beboncool Gamepad for Nintendo Switch Battery Replacement: adım 2, 2 resimden 1. Beboncool Gamepad for Nintendo Switch Battery Replacement: adım 2, 2 resimden 2.
    • Use the Phillips #0 screwdriver to remove the seven 5mm screws from the back of the controller.
  3. Beboncool Gamepad for Nintendo Switch Battery Replacement: adım 3, 3 resimden 1. Beboncool Gamepad for Nintendo Switch Battery Replacement: adım 3, 3 resimden 2. Beboncool Gamepad for Nintendo Switch Battery Replacement: adım 3, 3 resimden 3.
    • Gently separate the two halves of the controller.
    • As the two covers come apart the L1 and R1 button, will fall free from the controller. Be sure not to lose them if they should pop out and fall.
    • Be sure to slide the small circuit boards out of the covers to be able to separate the two halves
  4. Beboncool Gamepad for Nintendo Switch Battery Replacement: adım 4, 2 resimden 1. Beboncool Gamepad for Nintendo Switch Battery Replacement: adım 4, 2 resimden 2.
    • Use the Phillips #0 screwdriver to remove the two 3.5mm screws holding the circuit board in place.
  5. Beboncool Gamepad for Nintendo Switch Battery Replacement: adım 5, 3 resimden 1. Beboncool Gamepad for Nintendo Switch Battery Replacement: adım 5, 3 resimden 2. Beboncool Gamepad for Nintendo Switch Battery Replacement: adım 5, 3 resimden 3.
    • Lift the motherboard from the back case with the vibration motors and button boards attached.
  6. Beboncool Gamepad for Nintendo Switch Battery Replacement, Battery: adım 6, 3 resimden 1. Beboncool Gamepad for Nintendo Switch Battery Replacement, Battery: adım 6, 3 resimden 2. Beboncool Gamepad for Nintendo Switch Battery Replacement, Battery: adım 6, 3 resimden 3.
    • Carefully separate the battery which is adhered to the circuit board.
  7. Beboncool Gamepad for Nintendo Switch Battery Replacement: adım 7, 3 resimden 1. Beboncool Gamepad for Nintendo Switch Battery Replacement: adım 7, 3 resimden 2. Beboncool Gamepad for Nintendo Switch Battery Replacement: adım 7, 3 resimden 3.
Sonuç
Bir başkası bu kılavuzu tamamladı.
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 5
Son 30 gün: 21
Her zaman: 839
