Ana içeriğe geç
Beboncool Gamepad for Nintendo Switch Joystick Replacement
Neye ihtiyacın var
  1. Beboncool Gamepad for Nintendo Switch Joystick Replacement, Beboncool Nintendo Switch Gamepad Disassembly: adım 1, 3 resimden 1. Beboncool Gamepad for Nintendo Switch Joystick Replacement, Beboncool Nintendo Switch Gamepad Disassembly: adım 1, 3 resimden 2. Beboncool Gamepad for Nintendo Switch Joystick Replacement, Beboncool Nintendo Switch Gamepad Disassembly: adım 1, 3 resimden 3.
    • Use the plastic opening tool to remove the blue plastic grips from the sides of the controller.
  2. Beboncool Gamepad for Nintendo Switch Joystick Replacement: adım 2, 2 resimden 1. Beboncool Gamepad for Nintendo Switch Joystick Replacement: adım 2, 2 resimden 2.
    • Use the Phillips #0 screwdriver to remove the seven 5mm screws from the back of the controller.
  3. Beboncool Gamepad for Nintendo Switch Joystick Replacement: adım 3, 3 resimden 1. Beboncool Gamepad for Nintendo Switch Joystick Replacement: adım 3, 3 resimden 2. Beboncool Gamepad for Nintendo Switch Joystick Replacement: adım 3, 3 resimden 3.
    • Gently separate the two halves of the controller.
    • As the two covers come apart the L1 and R1 button, will fall free from the controller. Be sure not to lose them if they should pop out and fall.
    • Be sure to slide the small circuit boards out of the covers to be able to separate the two halves
  4. Beboncool Gamepad for Nintendo Switch Joystick Replacement: adım 4, 2 resimden 1. Beboncool Gamepad for Nintendo Switch Joystick Replacement: adım 4, 2 resimden 2.
    • Use the Phillips #0 screwdriver to remove the two 3.5mm screws holding the circuit board in place.
  5. Beboncool Gamepad for Nintendo Switch Joystick Replacement: adım 5, 3 resimden 1. Beboncool Gamepad for Nintendo Switch Joystick Replacement: adım 5, 3 resimden 2. Beboncool Gamepad for Nintendo Switch Joystick Replacement: adım 5, 3 resimden 3.
    • Lift the motherboard from the back case with the vibration motors and button boards attached.
  6. Beboncool Gamepad for Nintendo Switch Joystick Replacement, Joystick: adım 6, 2 resimden 1. Beboncool Gamepad for Nintendo Switch Joystick Replacement, Joystick: adım 6, 2 resimden 2.
    • Remove the joystick cover from the joystick actuator by firmly pulling the cover away from the actuator.
  7. Beboncool Gamepad for Nintendo Switch Joystick Replacement: adım 7, 2 resimden 1. Beboncool Gamepad for Nintendo Switch Joystick Replacement: adım 7, 2 resimden 2.
    • Gently separate the battery pack from the back of the motherboard, leaving it connected to the board through its lead cables.
  8. Beboncool Gamepad for Nintendo Switch Joystick Replacement: adım 8, 1 resimden 1.
    • Bend each of the retaining tabs located in the the corners of each joystick actuator straight so that they can be removed.
    • If only one of your joysticks is showing issues, just address the pins corresponding to the problematic joystick.
  9. Beboncool Gamepad for Nintendo Switch Joystick Replacement: adım 9, 3 resimden 1. Beboncool Gamepad for Nintendo Switch Joystick Replacement: adım 9, 3 resimden 2. Beboncool Gamepad for Nintendo Switch Joystick Replacement: adım 9, 3 resimden 3.
    • Desolder the 12 soldering points connecting the problematic actuator(s) to the motherboard.
    • Remove the actuator from the board.
    • For help with soldering best practices, check out this Soldering and Desoldering Connections Guide.
Sonuç
1Rehber Yorum
Me who used my no longer existing nails for the grips lol
TheGuyInTheChair - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 26
Her zaman: 866
