Giriş
The audio amplification PCB is the PCB which has the task of amplifying the B212D speaker's input signals.
Neye ihtiyacın var
There are two silver, 6 mm-long machine screws with two 1/8" inner-diameter washers on the exterior of the metal electronics box; remove these first using a #2 philips screwdriver.
There are five of the same type of machine screw (silver, 6 mm-long) remaining around the metal electronics box's exterior; remove these as well.
Remove the 4, 7/32" long machine screws with a #2 phillips head screwdriver.
Remove the 2 indicated flat head machine screws indicated using a #2 phillips head screwdriver.
5 farklı kişi bu kılavuzu tamamladı.
8Kılavuz Yorumları
lol pareil je cherche la pcb
I need the panel where I buy it
Calde.dc@GMAIL.COM
