Ana içeriğe geç
Belkin NetCam HD Plus Front Casing Replacement
Destinie DiazVerdejo
Destinie DiazVerdejo ve 2 diğer katkıda bulunanlar
En son March 2, 2021 tarihinde güncellendi
Tahmin yok
Orta
This guide will walk you through how to replace the front casing on the NetCam.
Neye ihtiyacın var
Aletler
Daha fazlasını göster…
  1. Belkin NetCam HD Plus Front Casing Replacement, Case: adım 1, 1 resimden 1.
    • Use a wrench to loosen up the stand from the back in order to hold the NetCam more comfortably.
  2. Belkin NetCam HD Plus Front Casing Replacement: adım 2, 1 resimden 1.
    • Work a plastic opening tool into the seam and pry the face plate away from the back panel.
  3. Belkin NetCam HD Plus Front Casing Replacement: adım 3, 2 resimden 1. Belkin NetCam HD Plus Front Casing Replacement: adım 3, 2 resimden 2.
    • Use pressure to separate the covers.
    • When pulling the device apart, separate from the bottom up in order to avoid pulling the wiring at the top apart.
  4. Belkin NetCam HD Plus Front Casing Replacement, Microphone: adım 4, 2 resimden 1. Belkin NetCam HD Plus Front Casing Replacement, Microphone: adım 4, 2 resimden 2.
    Bu adımda kullanılan alet:
    • Use tweezers to gently pull out the white attachment from the port.
    • Use your fingers to pull out the white attachment from the tan port on the front of the board a little.
  5. Belkin NetCam HD Plus Front Casing Replacement: adım 5, 2 resimden 1. Belkin NetCam HD Plus Front Casing Replacement: adım 5, 2 resimden 2.
    • Use a pair of tweezers to wedge between the mic and the rubber guard to remove the mic from the front cover.
    • If the rubber guard comes off with the mic just remove the guard from mic and place back on the front cover.
  6. Belkin NetCam HD Plus Front Casing Replacement, Front Casing: adım 6, 1 resimden 1.
    • Carefully use your fingers to gently pull out the white attachment from the tan colored part.
Sonuç
805 İtibar
7 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 3-5, Sullivan Fall 2016 USF Tampa, Team 3-5, Sullivan Fall 2016 üyesi
USFT-SULLIVAN-F16S3G5
4 Üyeler
14 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 4
Son 30 gün: 11
Her zaman: 338
