Ana içeriğe geç
Beyerdynamic MMX100 Volume Controller Repair
Neye ihtiyacın var
  1. Beyerdynamic MMX100 Volume Controller Repair, Beyerdynamic MMX100 Volume Controller Repair: adım 1, 3 resimden 1. Beyerdynamic MMX100 Volume Controller Repair, Beyerdynamic MMX100 Volume Controller Repair: adım 1, 3 resimden 2. Beyerdynamic MMX100 Volume Controller Repair, Beyerdynamic MMX100 Volume Controller Repair: adım 1, 3 resimden 3.
    • Twist the left speaker cushion towards you, and pull off the headset.
  2. Beyerdynamic MMX100 Volume Controller Repair: adım 2, 3 resimden 1. Beyerdynamic MMX100 Volume Controller Repair: adım 2, 3 resimden 2. Beyerdynamic MMX100 Volume Controller Repair: adım 2, 3 resimden 3.
    • Using the 2.0mm Phillips-Head screwdriver, unscrew the two 0.6mm screws at the end of the left side headband.
  3. Beyerdynamic MMX100 Volume Controller Repair: adım 3, 2 resimden 1. Beyerdynamic MMX100 Volume Controller Repair: adım 3, 2 resimden 2.
    • Hold open the top part of the headband. Slide out the left earphone.
  4. Beyerdynamic MMX100 Volume Controller Repair: adım 4, 3 resimden 1. Beyerdynamic MMX100 Volume Controller Repair: adım 4, 3 resimden 2. Beyerdynamic MMX100 Volume Controller Repair: adım 4, 3 resimden 3.
    • Using the 3.0mm Phillips-Head Screwdriver, unscrew the three 0.7 mm screws on the left speaker cover.
  5. Beyerdynamic MMX100 Volume Controller Repair: adım 5, 2 resimden 1. Beyerdynamic MMX100 Volume Controller Repair: adım 5, 2 resimden 2.
    • Using the 2.0mm Phillips-Head Screwdriver, unscrew the two 0.5mm screws on the volume control component.
  6. Beyerdynamic MMX100 Volume Controller Repair: adım 6, 3 resimden 1. Beyerdynamic MMX100 Volume Controller Repair: adım 6, 3 resimden 2. Beyerdynamic MMX100 Volume Controller Repair: adım 6, 3 resimden 3.
    • Take out, and flip over, the volume control component.
  7. Beyerdynamic MMX100 Volume Controller Repair: adım 7, 2 resimden 1. Beyerdynamic MMX100 Volume Controller Repair: adım 7, 2 resimden 2.
    • Using the 2.0mm Phillips-Head Screwdriver, unscrew the two 0.3mm screws on the board. Then, take off the volume wheel.
  8. Beyerdynamic MMX100 Volume Controller Repair: adım 8, 2 resimden 1. Beyerdynamic MMX100 Volume Controller Repair: adım 8, 2 resimden 2.
    • Hazardous situation which, if not avoided, could result in minor or moderate injury.
    • Using a soldering iron, desolder the damaged wires and the prongs on either side of the board.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Anthony Grande
205 İtibar
1 Kılavuz yazıldı
Ekip
CSU Los Angeles, Team 5-9, Kershman Fall 2023 CSU Los Angeles, Team 5-9, Kershman Fall 2023 üyesi
CSULA-KERSHMAN-F23S5G9
1 Üye
3 adet Kılavuz yazıldı
1Rehber Yorum
I have these MMX100 headphones and I want to attempt this repair, but I was wondering where I could find a suitable replacement part for the rotary encoder.
SoupspoonDx - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 13
Son 30 gün: 103
Her zaman: 1,786
