Ana içeriğe geç
Bike Chain Removal
Bike Chain Removal
aaron thielk
aaron thielk ve 6 diğer katkıda bulunanlar
En son July 8, 2021 tarihinde güncellendi
5 - 10 dakika
Orta
In this guide you will learn how to take a chain off a bike using a chain cutting tool. Be careful to not force the pin out incorrectly. If it is difficult to press the pin out, the tool is most likely not aligned up properly. Greasing the threads of the chain cutting tool will make it easier to press out the pin.
Neye ihtiyacın var
  1. Bike Chain Removal, Bike Chain Removal: adım 1, 2 resimden 1. Bike Chain Removal, Bike Chain Removal: adım 1, 2 resimden 2.
    • Slide the chain cutting tool onto the desired link.
    • Align the push pin of the tool with the pin on the chain, and tighten the tool until the pin protrudes out the other side without falling all the way out.
  2. Bike Chain Removal: adım 2, 1 resimden 1.
    • Stop pushing the pin out when it is just held in by the outer link, so it doesn't fall all the way out. You will still be able to separate the links.
    • Repeat the previous step to take off sections of links.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
aaron thielk
1.903 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 5-13, Maness Fall 2010 Cal Poly, Team 5-13, Maness Fall 2010 üyesi
CPSU-MANESS-F10S5G13
4 Üyeler
17 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 10
Son 30 gün: 20
Her zaman: 8,151
