Ana içeriğe geç
Bike Chain Replacement
Camara Dylan
Camara Dylan ve başka bir katkıda bulunan
En son November 29, 2023 tarihinde güncellendi
1 dakika
Orta
Topluluk-Katkılı Kılavuz
Inner and outer plate pairs that are fastened together with pins form chains. In the end, your bike's chain engages the gears. Your bike is probably unrideable if a chain is out of balance. These are some of the most typical issues with bike chains, along with solutions.
Neye ihtiyacın var
  1. Bike Chain Replacement, Pick up the slipped chain and position: adım 1, 1 resimden 1.
    • Pick up the slipped chain and position it to the top of the correct gear while pedaling.
  2. Bike Chain Replacement, Release the derailleur and push the pedal forward: adım 2, 1 resimden 1.
    • Once the chain teeth are locked in place, slowly release the derailleur and push the pedal forward to move the back wheel.
  3. Bike Chain Replacement, Continue pedaling: adım 3, 1 resimden 1.
    • Continue pedaling until the rest of the chains are fit back into their original positions
    • Before you get back on your bike, shift to the lowest gear and continue pedaling. This movement should realign your chain and lock it back into place.
  4. Bike Chain Replacement, Reminder: adım 5, 1 resimden 1.
    • Changing gears without pedaling can cause the chain to bind up, and should be avoided.
Sonuç
Camara Dylan
121 İtibar
1 Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 19
Her zaman: 154
