Ana içeriğe geç
Black and Decker PS1800 Switch Replacement
Neye ihtiyacın var
  1. Black and Decker PS1800  Switch Replacement, Open the Outer Drill Case: adım 1, 2 resimden 1. Black and Decker PS1800  Switch Replacement, Open the Outer Drill Case: adım 1, 2 resimden 2.
    • Lay the drill on its side, assuring that the screw holes are facing upwards.
    • Remove seven 12 mm screws using a Phillips #00 screwdriver.
  2. Black and Decker PS1800  Switch Replacement: adım 2, 1 resimden 1.
    • Separate the outer drill case to expose the components and switch.
  3. Black and Decker PS1800  Switch Replacement, Switch: adım 3, 2 resimden 1. Black and Decker PS1800  Switch Replacement, Switch: adım 3, 2 resimden 2.
    • Identify the switch in center of the drill.
    • Remove the screws from the switch.
    • Remove the switch cover.
  4. Black and Decker PS1800  Switch Replacement: adım 4, 1 resimden 1.
    • Locate the switch inside the drill.
    • Remove the switch from the drill.
  5. Black and Decker PS1800  Switch Replacement: adım 5, 2 resimden 1. Black and Decker PS1800  Switch Replacement: adım 5, 2 resimden 2.
    • Solder off all the joints.
    • Remove the switch assembly.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Hamza Nawaz
247 İtibar
2 adet Kılavuz yazıldı
Ekip
IUPUI, Team 2-3, Baechle Fall 2016 IUPUI, Team 2-3, Baechle Fall 2016 üyesi
IUPUI-BAECHLE-F16S2G3
5 Üyeler
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 16
Her zaman: 944
