Giriş
This guide is used to replace your toast oven door completely. If your handle is broken or melted, you will have to replace the door fully. You will have to remove the top cover, control knobs, and the door spring in order to remove the door. There are five steps in this guide to help you get your door replaced.
Neye ihtiyacın var
Remove the six 9.5mm screws on the back panel using a #2 Phillips screwdriver.
With the needle nose pliers, grasp the hook of the rear spring as close as you can to the coils. Stretch the spring back and, with a twisting motion, pull the hook out of its catch.
Remove the two #2 Phillips Head x 5.5mm screws holding the timer controls to the face.
1Rehber Yorum
I have the Black and Decker TROS1500 SpaceMaker Toaster Oven and the door handle fell off. Although my model is somewhat different, these images gave me the confidence to disassemble the unit and remove the door to work on the handle. I thought a rivet had broken, but it turned out that the handle attaches with screws and the screws had just come loose. I could have fixed that without disassembly, but I may not have started if I hadn’t seen this page. Kudos to you and IFIXIT!
I was not able to find any repair images or video on Google or YouTube. The SpaceMaker line is down to one model with mediocre reviews. I’m glad I was able to repair mine and save $130.
