Ana içeriğe geç
Black and Decker Toast R Oven On/Off switch Replacement
Jonathan
Jonathan ve 3 diğer katkıda bulunanlar
En son February 19, 2016 tarihinde güncellendi
Tahmin yok
Orta
Dilim ve Zar
Daha İyi Resimler Gerekli
In order to replace to On/Off switch, you will once again have to take apart the whole unit to get to that part.
Neye ihtiyacın var
iFixit bu bağlantılar üzerinden satın aldığınızda komisyon kazanır.
  1. Black and Decker Toast R Oven On/Off switch Replacement, How to clean out a Black and Decker Toast R Oven: adım 1, 1 resimden 1.
    • Make sure that the toaster is unplugged before you begin.
    • Turn the toaster over with its backside face down.
    • Remove the two Phillips #4 1cm screws that attach the side panels.
  2. Black and Decker Toast R Oven On/Off switch Replacement: adım 2, 2 resimden 1. Black and Decker Toast R Oven On/Off switch Replacement: adım 2, 2 resimden 2.
    • Pull downwards (towards the bottom of the unit) and outward to remove the side panels.
  3. Black and Decker Toast R Oven On/Off switch Replacement: adım 3, 1 resimden 1.
    • Remove the metal vent piece that is below the door.
    • This should slide off easily once both of the side panels are removed.
  4. Black and Decker Toast R Oven On/Off switch Replacement: adım 4, 1 resimden 1.
    • Remove the two Phillips #4 1 cm screws, which connect the bottom panel to the unit.
  5. Black and Decker Toast R Oven On/Off switch Replacement: adım 5, 1 resimden 1.
    • Remove the crumb tray (the bottom, metal panel) from the toaster unit.
  6. Black and Decker Toast R Oven On/Off switch Replacement: adım 6, 1 resimden 1.
    • Remove the aluminum strip from the bottom of unit; this is the piece that is directly under the door.
  7. Black and Decker Toast R Oven On/Off switch Replacement: adım 7, 1 resimden 1.
    • Remove the knobs by pulling them upward; they should slide right off.
    • When placing the knobs back on the unit, make sure the semicircle notch fits correctly in the hole so that the knobs don't fall off.
  8. Black and Decker Toast R Oven On/Off switch Replacement: adım 8, 1 resimden 1.
    • Unhook the bottom of the the display panel from the toaster unit.
    • It will be a little tough to pry off, but don't be afraid to be forceful. You can use your hands, or pliers, to bend the metal piece backwards.
  9. Black and Decker Toast R Oven On/Off switch Replacement: adım 9, 1 resimden 1.
    • Begin to detach the back panel from the toaster unit.
    • Then, unhook the rest of the display panel.
    • This will also be a little tough to get off, but don't be afraid to be forceful.
  10. Black and Decker Toast R Oven On/Off switch Replacement: adım 10, 1 resimden 1.
    • Finish removing the outside cover by lifting the lid upward.
  11. Black and Decker Toast R Oven On/Off switch Replacement: adım 11, 1 resimden 1.
    • Remove the four Phillips #4 1 cm screws from the back of the unit.
  12. Black and Decker Toast R Oven On/Off switch Replacement: adım 12, 1 resimden 1.
    • Now, you can clean the outside units of the toaster oven.
  13. Black and Decker Toast R Oven On/Off switch Replacement: adım 13, 1 resimden 1.
    • Remove the the heating coil protection bar from the toaster unit by first pulling out the left side.
  14. Black and Decker Toast R Oven On/Off switch Replacement, On/Off switch: adım 14, 1 resimden 1.
    • Remove the two Phillips #4 1 cm screws that were under the faceplate.
  15. Black and Decker Toast R Oven On/Off switch Replacement: adım 15, 2 resimden 1. Black and Decker Toast R Oven On/Off switch Replacement: adım 15, 2 resimden 2.
    • Forcefully bend back the faceplate in order to get to the knob.
  16. Black and Decker Toast R Oven On/Off switch Replacement: adım 16, 1 resimden 1.
    • Remove pin holding the On/Off switch in place.
  17. Black and Decker Toast R Oven On/Off switch Replacement: adım 17, 1 resimden 1.
    • Remove switch from the opening it protrudes from.
    • This will take a little bit of manipulating but it will come out.
Sonuç
To reassemble your device, follow these instructions in reverse order. It will look like the faceplate is still bent out, but after you put the screws back in it will come back into place.
3 farklı kişi bu kılavuzu tamamladı.
Jonathan
320 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 2-10, Propen Fall 2012 Cal Poly, Team 2-10, Propen Fall 2012 üyesi
CPSU-PROPEN-F12S2G10
4 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 6
Son 7 gün: 12
Son 30 gün: 58
Her zaman: 10,602
