Giriş
If the buttons on your BlackBerry Tour 9630 are unresponsive or become difficult to push, then your keypad is probably damaged or dirty. Use these step-by-step instructions to replace your BlackBerry Tour 9630 keypad and get it working like new again!
Neye ihtiyacın var
Position the phone so that the keyboard is facing down and the back is facing up.
If there is an SD card, press gently on the card and slide it up to remove.
If there is a SIM card, press gently on the card and slide it left to remove.
Use the T6 Torx screwdriver to remove the four 8.00 mm screws from the back of the phone.
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
