Blink Video Doorbell Back Panel Replacement
Neye ihtiyacın var
Push the opening key into the small opening with the two gray buttons on the bottom of the device.
Push the device up from the mount and slide it off.
Remove the two 6 mm screws in the battery compartment using a JIS #1 screwdriver.
Remove the two 7 mm screws above the battery compartment using a JIS #1 screwdriver.
Starting from the bottom of the device, pry the back plate away from the rest of the doorbell.
