Ana içeriğe geç
Blink Video Doorbell LED Light Replacement
Neye ihtiyacın var
  1. Blink Video Doorbell LED Light Replacement, Battery: adım 1, 3 resimden 1. Blink Video Doorbell LED Light Replacement, Battery: adım 1, 3 resimden 2. Blink Video Doorbell LED Light Replacement, Battery: adım 1, 3 resimden 3.
    • Push the opening key into the small opening with the two gray buttons on the bottom of the device.
    • The device will click off the mount.
    • Push the device up from the mount and slide it off.
  2. Blink Video Doorbell LED Light Replacement: adım 2, 3 resimden 1. Blink Video Doorbell LED Light Replacement: adım 2, 3 resimden 2. Blink Video Doorbell LED Light Replacement: adım 2, 3 resimden 3.
    • Use your finger to slide the gray tab, located near the bottom of the device, upwards.
    • Remove the battery cover.
  3. Blink Video Doorbell LED Light Replacement: adım 3, 3 resimden 1. Blink Video Doorbell LED Light Replacement: adım 3, 3 resimden 2. Blink Video Doorbell LED Light Replacement: adım 3, 3 resimden 3.
    • Remove the right battery by pushing the positive end down and pulling the battery out toward yourself.
    • Repeat the procedure for the left battery.
    • Do not mix used and new batteries or batteries of different types (for example, lithium and alkaline batteries).
  4. Blink Video Doorbell LED Light Replacement, Back Panel: adım 4, 3 resimden 1. Blink Video Doorbell LED Light Replacement, Back Panel: adım 4, 3 resimden 2. Blink Video Doorbell LED Light Replacement, Back Panel: adım 4, 3 resimden 3.
    • Remove the two 6 mm screws in the battery compartment using a JIS #1 screwdriver.
    • Remove the two 7 mm screws above the battery compartment using a JIS #1 screwdriver.
    • Starting from the bottom of the device, pry the back plate away from the rest of the doorbell.
  5. Blink Video Doorbell LED Light Replacement, LED Light: adım 5, 3 resimden 1. Blink Video Doorbell LED Light Replacement, LED Light: adım 5, 3 resimden 2. Blink Video Doorbell LED Light Replacement, LED Light: adım 5, 3 resimden 3.
    • Remove the three 6 mm screws from the upper part of the motherboard using a JIS #1 screwdriver.
    • Use an opening tool to release the motherboard from the device.
  6. Blink Video Doorbell LED Light Replacement: adım 6, 3 resimden 1. Blink Video Doorbell LED Light Replacement: adım 6, 3 resimden 2. Blink Video Doorbell LED Light Replacement: adım 6, 3 resimden 3.
    • Use a soldering iron to desolder the LED connections from the motherboard.
Sonuç
Kayla Crai
495 İtibar
4 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 1-1, Konn Fall 2024 UMass Dartmouth, Team 1-1, Konn Fall 2024 üyesi
UMASSD-KONN-F24S1G1
4 Üyeler
5 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 6
Son 30 gün: 33
Her zaman: 93
