Ana içeriğe geç
Blu L120 Rear Facing Camera Replacement
Neye ihtiyacın var
  1. Blu L120 Rear Facing Camera Replacement, Remove back panel: adım 1, 3 resimden 1. Blu L120 Rear Facing Camera Replacement, Remove back panel: adım 1, 3 resimden 2. Blu L120 Rear Facing Camera Replacement, Remove back panel: adım 1, 3 resimden 3.
    • Remove the cover by lifting the notch towards the bottom of the phone. Use your fingernail to lift it up.
  2. Blu L120 Rear Facing Camera Replacement, Screw Removal: adım 2, 3 resimden 1. Blu L120 Rear Facing Camera Replacement, Screw Removal: adım 2, 3 resimden 2. Blu L120 Rear Facing Camera Replacement, Screw Removal: adım 2, 3 resimden 3.
    • Remove these nine screws with a small phillips screwdriver. They are all the same size.
    • There is a small screw hidden under the warranty sticker. You may either remove or poke through it .
  3. Blu L120 Rear Facing Camera Replacement, Rear Panel  removal: adım 3, 3 resimden 1. Blu L120 Rear Facing Camera Replacement, Rear Panel  removal: adım 3, 3 resimden 2. Blu L120 Rear Facing Camera Replacement, Rear Panel  removal: adım 3, 3 resimden 3.
    • Use the pry tool to gently separate the panel from the frame, starting from the bottom left corner and continue along the edge of the phone.
    • *WARNING* by doing this, you will void the manufacturers warranty.
  4. Blu L120 Rear Facing Camera Replacement, Separate back panel from frame: adım 4, 3 resimden 1. Blu L120 Rear Facing Camera Replacement, Separate back panel from frame: adım 4, 3 resimden 2. Blu L120 Rear Facing Camera Replacement, Separate back panel from frame: adım 4, 3 resimden 3.
    • Continue using the pry tool around the back panel of the phone to separate both pieces.
    • Once you have gone around the entire frame, use both hands to pull it apart.
  5. Blu L120 Rear Facing Camera Replacement, Camera Removal: adım 5, 3 resimden 1. Blu L120 Rear Facing Camera Replacement, Camera Removal: adım 5, 3 resimden 2. Blu L120 Rear Facing Camera Replacement, Camera Removal: adım 5, 3 resimden 3.
    Bu adımda kullanılan alet:
    Satın Al
    • Use the pry tool to disconnect the camera from the device.
    • Gently lift the camera up and use the tweezers to remove it from the phone.
    • Reinstall the camera. Then follow the guide in reverse to put the phone back together.
Sonuç
Julio
695 İtibar
6 adet Kılavuz yazıldı
Ekip
Gateway, Team 1-5, Johnson Fall 2014 Gateway, Team 1-5, Johnson Fall 2014 üyesi
GCC-JOHNSON-F14S1G5
3 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 3
Her zaman: 222
