Ana içeriğe geç
Blu L120 Screen Assembly Replacement
Neye ihtiyacın var
  1. Blu L120 Screen Assembly Replacement, Remove back panel: adım 1, 3 resimden 1. Blu L120 Screen Assembly Replacement, Remove back panel: adım 1, 3 resimden 2. Blu L120 Screen Assembly Replacement, Remove back panel: adım 1, 3 resimden 3.
    • Remove the cover by lifting the notch towards the bottom of the phone. Use your fingernail to lift it up.
  2. Blu L120 Screen Assembly Replacement, Screw Removal: adım 2, 3 resimden 1. Blu L120 Screen Assembly Replacement, Screw Removal: adım 2, 3 resimden 2. Blu L120 Screen Assembly Replacement, Screw Removal: adım 2, 3 resimden 3.
    • Remove these nine screws with a small phillips screwdriver. They are all the same size.
    • There is a small screw hidden under the warranty sticker. You may either remove or poke through it .
  3. Blu L120 Screen Assembly Replacement, Rear Panel  removal: adım 3, 3 resimden 1. Blu L120 Screen Assembly Replacement, Rear Panel  removal: adım 3, 3 resimden 2. Blu L120 Screen Assembly Replacement, Rear Panel  removal: adım 3, 3 resimden 3.
    • Use the pry tool to gently separate the panel from the frame, starting from the bottom left corner and continue along the edge of the phone.
    • *WARNING* by doing this, you will void the manufacturers warranty.
  4. Blu L120 Screen Assembly Replacement, Separate back panel from frame: adım 4, 3 resimden 1. Blu L120 Screen Assembly Replacement, Separate back panel from frame: adım 4, 3 resimden 2. Blu L120 Screen Assembly Replacement, Separate back panel from frame: adım 4, 3 resimden 3.
    • Continue using the pry tool around the back panel of the phone to separate both pieces.
    • Once you have gone around the entire frame, use both hands to pull it apart.
  5. Blu L120 Screen Assembly Replacement, Camera Removal: adım 5, 3 resimden 1. Blu L120 Screen Assembly Replacement, Camera Removal: adım 5, 3 resimden 2. Blu L120 Screen Assembly Replacement, Camera Removal: adım 5, 3 resimden 3.
    Bu adımda kullanılan alet:
    • Use the pry tool to disconnect the camera from the device.
    • Gently lift the camera up and use the tweezers to remove it from the phone.
    • Reinstall the camera. Then follow the guide in reverse to put the phone back together.
  6. Blu L120 Screen Assembly Replacement, Motherboard: adım 6, 3 resimden 1. Blu L120 Screen Assembly Replacement, Motherboard: adım 6, 3 resimden 2. Blu L120 Screen Assembly Replacement, Motherboard: adım 6, 3 resimden 3.
    • Remove these three screws using 00 Philips screwdriver. Note the smaller screw circled in orange.
    • Then gently pry up on the metal antenna connector at the end of the grey wire. Move the wire out of the way.
  7. Blu L120 Screen Assembly Replacement: adım 7, 2 resimden 1. Blu L120 Screen Assembly Replacement: adım 7, 2 resimden 2.
    • Next you must disconnect these three cables.
    • Use your pry tool to lift up on the brown tab to release the ribbon cable.
  8. Blu L120 Screen Assembly Replacement: adım 8, 3 resimden 1. Blu L120 Screen Assembly Replacement: adım 8, 3 resimden 2. Blu L120 Screen Assembly Replacement: adım 8, 3 resimden 3.
    • For the last ribbon cable, use a spudger to gently pry up on the board under the right sim card slot.
    • Next, take your pry tool to lift up on the brown tab holding down the ribbon cable.
    • The cable is now free to be pulled back out of its' slot.
  9. Blu L120 Screen Assembly Replacement: adım 9, 3 resimden 1. Blu L120 Screen Assembly Replacement: adım 9, 3 resimden 2. Blu L120 Screen Assembly Replacement: adım 9, 3 resimden 3.
    • Using a spudger, peel up on the mesh tape then use your tweezers to peel the rest of it up.
  10. Blu L120 Screen Assembly Replacement: adım 10, 3 resimden 1. Blu L120 Screen Assembly Replacement: adım 10, 3 resimden 2. Blu L120 Screen Assembly Replacement: adım 10, 3 resimden 3.
    • Now that the motherboard is free to be pried up, be sure that no cables are in the way or can be snagged when removing the motherboard.
    • Just lift up and away.
    • Follow the instructions in reverse to put the phone back together.
  11. Blu L120 Screen Assembly Replacement, Screen Assembly: adım 11, 2 resimden 1. Blu L120 Screen Assembly Replacement, Screen Assembly: adım 11, 2 resimden 2.
    • Using your tweezers, peel back the yellow film to free the cable from the screen.
  12. Blu L120 Screen Assembly Replacement: adım 12, 2 resimden 1. Blu L120 Screen Assembly Replacement: adım 12, 2 resimden 2.
    • We used the iOpener tool, heated it up, and placed it on top of the phone for a few seconds to loosen up the glue.
  13. Blu L120 Screen Assembly Replacement: adım 13, 3 resimden 1. Blu L120 Screen Assembly Replacement: adım 13, 3 resimden 2. Blu L120 Screen Assembly Replacement: adım 13, 3 resimden 3.
    • Once the screen has been heated and the glue is tacky, put a plastic opening tool between the glass screen and the frame. Start lifting the glass away around the whole frame.
  14. Blu L120 Screen Assembly Replacement: adım 14, 3 resimden 1. Blu L120 Screen Assembly Replacement: adım 14, 3 resimden 2. Blu L120 Screen Assembly Replacement: adım 14, 3 resimden 3.
    • When finished separating the glass from the frame with the pry tool, grab both the frame and glass with both hands and separate both pieces. CAUTION, there is a ribbon cable that needs to be removed from the back of the phone before full separation.
    • As you can see, the LCD still needs a bit more work to come apart.
  15. Blu L120 Screen Assembly Replacement: adım 15, 3 resimden 1. Blu L120 Screen Assembly Replacement: adım 15, 3 resimden 2. Blu L120 Screen Assembly Replacement: adım 15, 3 resimden 3.
    • Take a spudger and gently push the cable through the cutout on the frame to separate the glass.
  16. Blu L120 Screen Assembly Replacement: adım 16, 2 resimden 1. Blu L120 Screen Assembly Replacement: adım 16, 2 resimden 2.
    • Congratulations! Your device is now ready for a new glass panel!
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Julio
695 İtibar
6 adet Kılavuz yazıldı
Ekip
Gateway, Team 1-5, Johnson Fall 2014 Gateway, Team 1-5, Johnson Fall 2014 üyesi
GCC-JOHNSON-F14S1G5
3 Üyeler
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 22
Her zaman: 1,908
