Ana içeriğe geç
Blu Grand M2 Charging Port Assembly Replacement
Neye ihtiyacın var
  1. Blu Grand M2 Charging Port Assembly Replacement, Charging Port Assembly: adım 1, 1 resimden 1.
    • Remove the screws with the T2 Torx screwdriver.
    • Place screws off to the side.
  2. Blu Grand M2 Charging Port Assembly Replacement: adım 2, 2 resimden 1. Blu Grand M2 Charging Port Assembly Replacement: adım 2, 2 resimden 2.
    • Once the Torx screws have been removed, use a pry tool and a suction tool to remove the back plate.
    • Using the T2 Torx screwdriver, remove the six Torx screws on the motherboard.
    • Make sure to disconnect all other connections from the camera.
  3. Blu Grand M2 Charging Port Assembly Replacement: adım 3, 1 resimden 1.
    • Carefully pry the motherboard assembly from the phone.
    • The charging port assembly is soldered to the motherboard piece. Remove the port with a soldering iron.
    • Once you have removed the faulty port, replace it with the new port. Attach the new charging port with the soldering iron.
    • After installing the new port, repeat the steps in reverse order to reassemble the phone.
    • How to Solder and Desolder Connections
Sonuç
Bir başkası bu kılavuzu tamamladı.
Richard Hills
150 İtibar
1 Kılavuz yazıldı
Ekip
Gateway, Team S1-G3, Luster Fall 2018 Gateway, Team S1-G3, Luster Fall 2018 üyesi
GCC-LUSTER-F18S1G3
4 Üyeler
4 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 7
Son 30 gün: 14
Her zaman: 502
