Ana içeriğe geç
Boosted Board 1st Generation Pulley Bearings Replacement
Neye ihtiyacın var
  1. Boosted Board 1st Generation Pulley Bearings Replacement, Rear Wheels: adım 1, 2 resimden 1. Boosted Board 1st Generation Pulley Bearings Replacement, Rear Wheels: adım 1, 2 resimden 2.
    • Loosen the two 16.74 mm motor mount hex nut screws with a 9/64" Allen wrench.
    • Do Not Remove the Screws.
  2. Boosted Board 1st Generation Pulley Bearings Replacement: adım 2, 1 resimden 1.
    • Compress the motor mount back towards the wheel.
    • While keeping the motor mount compressed, tighten one of the hex nuts that you loosened in the previous step.
    • The motor mounts are spring tensioned so it is necessary compress them to loosen the belts.
  3. Boosted Board 1st Generation Pulley Bearings Replacement: adım 3, 2 resimden 1. Boosted Board 1st Generation Pulley Bearings Replacement: adım 3, 2 resimden 2.
    • Remove the axel nut with a 1/2" socket wrench
  4. Boosted Board 1st Generation Pulley Bearings Replacement: adım 4, 3 resimden 1. Boosted Board 1st Generation Pulley Bearings Replacement: adım 4, 3 resimden 2. Boosted Board 1st Generation Pulley Bearings Replacement: adım 4, 3 resimden 3.
    • Rotate and pull counterclockwise until the wheel comes off the axle completely.
    • The front washer will come off with the wheel.
    • Remove the back washer from the axle.
    • Replacing the wheel requires the bearings to be switched into the new wheel.
  5. Boosted Board 1st Generation Pulley Bearings Replacement, Pulley Bearings: adım 5, 2 resimden 1. Boosted Board 1st Generation Pulley Bearings Replacement, Pulley Bearings: adım 5, 2 resimden 2.
    • Use one finger to pull out the pulley bearing.
    • A good technique is to go around in a circle and lift from underneath the bearing in a carving motion.
  6. Boosted Board 1st Generation Pulley Bearings Replacement: adım 6, 3 resimden 1. Boosted Board 1st Generation Pulley Bearings Replacement: adım 6, 3 resimden 2. Boosted Board 1st Generation Pulley Bearings Replacement: adım 6, 3 resimden 3.
    • Place the new pulley bearing inside the gear hole and use two fingers to push down evenly until it slides into place.
    • The bearing should be flush with the gear
Sonuç
Emily Imfeld
532 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 15-7, Livingston Fall 2016 Cal Poly, Team 15-7, Livingston Fall 2016 üyesi
CPSU-LIVINGSTON-F16S15G7
4 Üyeler
6 adet Kılavuz yazıldı
1Rehber Yorum
you mentioned cleaning bearings how do you go about that? (if rep[lacing not an option at moment) Also I noticed a single Large Bearing in my replacement kit, what is that and where do I replace it as I don’t see where it could be (I have a first Gen)
Rick Gram - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 11
Son 30 gün: 14
Her zaman: 1,673
