Ana içeriğe geç
Boosted Board 1st Generation Rear Wheels Replacement
Emily Imfeld
Emily Imfeld ve 4 diğer katkıda bulunanlar
En son November 30, 2016 tarihinde güncellendi
20 dakika
Orta
This guide will help teach you how to take off the rear wheels of your Boosted Board.
Neye ihtiyacın var
iFixit bu bağlantılar üzerinden satın aldığınızda komisyon kazanır.
  1. Boosted Board 1st Generation Rear Wheels Replacement, Rear Wheels: adım 1, 2 resimden 1. Boosted Board 1st Generation Rear Wheels Replacement, Rear Wheels: adım 1, 2 resimden 2.
    • Loosen the two 16.74 mm motor mount hex nut screws with a 9/64" Allen wrench.
    • Do Not Remove the Screws.
  2. Boosted Board 1st Generation Rear Wheels Replacement: adım 2, 1 resimden 1.
    • Compress the motor mount back towards the wheel.
    • While keeping the motor mount compressed, tighten one of the hex nuts that you loosened in the previous step.
    • The motor mounts are spring tensioned so it is necessary compress them to loosen the belts.
  3. Boosted Board 1st Generation Rear Wheels Replacement: adım 3, 2 resimden 1. Boosted Board 1st Generation Rear Wheels Replacement: adım 3, 2 resimden 2.
    • Remove the axel nut with a 1/2" socket wrench
  4. Boosted Board 1st Generation Rear Wheels Replacement: adım 4, 3 resimden 1. Boosted Board 1st Generation Rear Wheels Replacement: adım 4, 3 resimden 2. Boosted Board 1st Generation Rear Wheels Replacement: adım 4, 3 resimden 3.
    • Rotate and pull counterclockwise until the wheel comes off the axle completely.
    • The front washer will come off with the wheel.
    • Remove the back washer from the axle.
    • Replacing the wheel requires the bearings to be switched into the new wheel.
Sonuç
Emily Imfeld
532 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 15-7, Livingston Fall 2016 Cal Poly, Team 15-7, Livingston Fall 2016 üyesi
CPSU-LIVINGSTON-F16S15G7
4 Üyeler
6 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 8
Son 30 gün: 13
Her zaman: 1,318
