Ana içeriğe geç
Boosted Board 1st Generation Remote Battery Replacement
Neye ihtiyacın var
  1. Boosted Board 1st Generation Remote Battery Replacement, Remote Battery: adım 1, 3 resimden 1. Boosted Board 1st Generation Remote Battery Replacement, Remote Battery: adım 1, 3 resimden 2. Boosted Board 1st Generation Remote Battery Replacement, Remote Battery: adım 1, 3 resimden 3.
    • Before disassembling your remote, be sure it is powered off.
    • Remove the four 17.57mm screws from the bottom of the case with a PH0 screwdriver.
    hi my name is Eugene.  I have a question .  My skateboard remote is gone.  remotes are not sold in my country.  what should i do how can i use the skateboard .  we sell remotes from another company.  how can it be adjusted to my boosted mini .  help me solve the issue please.
    Evgeny Bubnov - Yanıt
  2. Boosted Board 1st Generation Remote Battery Replacement: adım 2, 2 resimden 1. Boosted Board 1st Generation Remote Battery Replacement: adım 2, 2 resimden 2.
    • Carefully separate the two halves of the casing by pulling them apart at the seam.
    • Be sure to keep the scroll wheel, lever and buttons attached to the housing.
  3. Boosted Board 1st Generation Remote Battery Replacement: adım 3, 3 resimden 1. Boosted Board 1st Generation Remote Battery Replacement: adım 3, 3 resimden 2. Boosted Board 1st Generation Remote Battery Replacement: adım 3, 3 resimden 3.
    • Remove the rectangular black adhesive foam on top of the battery by peeling it away from the battery.
    • Desolder the battery connections from the circuit board.
    • Replace the dead battery with a new 3.7 volt lithium polymer battery.
    • Refer here for more information how to desolder the battery.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Kevin Manko
164 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 15-7, Livingston Fall 2016 Cal Poly, Team 15-7, Livingston Fall 2016 üyesi
CPSU-LIVINGSTON-F16S15G7
4 Üyeler
6 adet Kılavuz yazıldı
4Kılavuz Yorumları
Where can I get the battery? Or can you give specs? Thanks!
Dan Davie - Yanıt
You can't use 3rd party remotes with proprietary Boosted products.
Tom Tamaira -
Verified this works with V2 and V3 remotes as well. I did a R29 and it works great. Thank you for the info.
Thayne Christiansen - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 17
Son 30 gün: 70
Her zaman: 5,105
