Ana içeriğe geç
Bosch arriva 1500 W Disassembly
Elisabeth Kvaalen
Elisabeth Kvaalen ve başka bir katkıda bulunan
En son December 10, 2020 tarihinde güncellendi
Tahmin yok
Kolay
Topluluk-Katkılı Kılavuz
You may want to open it up to clean out the fine particles of dust that accumulate inside, or to straighten out the electric plug if it gets jammed up inside. This is if you are lucky enough to have a motor that still works. I don’t advise opening and closing the vacuum cleaner too often: with time, the plastic clips may wear down and compromise the air-tight fit.
Neye ihtiyacın var
  1. Bosch arriva 1500 W Disassembly, Opening: adım 1, 2 resimden 1. Bosch arriva 1500 W Disassembly, Opening: adım 1, 2 resimden 2.
    • Remove the top cap, and any filters.
  2. Bosch arriva 1500 W Disassembly, Unscrew the body of the motor: adım 2, 1 resimden 1.
    • There is only one screw to remove, at the back of the vacuum cleaner.
    • Put the screw in a safe place
  3. Bosch arriva 1500 W Disassembly, Un clipping the body of the motor: adım 3, 2 resimden 1. Bosch arriva 1500 W Disassembly, Un clipping the body of the motor: adım 3, 2 resimden 2.
    • Use a screwdriver to unclip the body of the motor. There are two clips in front and one on the side of the plug (towards the back).
  4. Bosch arriva 1500 W Disassembly: adım 4, 1 resimden 1.
    • Remove the top of the body of the motor.
  5. Bosch arriva 1500 W Disassembly, Removing on/off button: adım 5, 1 resimden 1.
    • Remove the on/off button.
  6. Bosch arriva 1500 W Disassembly, Removing electric plug coil: adım 6, 2 resimden 1. Bosch arriva 1500 W Disassembly, Removing electric plug coil: adım 6, 2 resimden 2.
    • Slide the electric plug coil out of its rails.
    • For reassembling, see step 10.
  7. Bosch arriva 1500 W Disassembly: adım 7, 1 resimden 1.
    • Slide the electric circuit board out of the electric plug coil.
  8. Bosch arriva 1500 W Disassembly, Removing the motor: adım 8, 2 resimden 1. Bosch arriva 1500 W Disassembly, Removing the motor: adım 8, 2 resimden 2.
    • Lift out the motor.
    • Gently unwrap the fleece.
  9. Bosch arriva 1500 W Disassembly, The motor: adım 9, 3 resimden 1. Bosch arriva 1500 W Disassembly, The motor: adım 9, 3 resimden 2. Bosch arriva 1500 W Disassembly, The motor: adım 9, 3 resimden 3.
    • The motor is held in place by two rubber pieces on either side.
    • You may remove these rubber parts from the motor
  10. Bosch arriva 1500 W Disassembly, Reassembling step 6: adım 10, 3 resimden 1. Bosch arriva 1500 W Disassembly, Reassembling step 6: adım 10, 3 resimden 2. Bosch arriva 1500 W Disassembly, Reassembling step 6: adım 10, 3 resimden 3.
    • Re-assemble in reverse order until step 6.
    • Slide the plug coil into its rails. Make sure that the coil is completely wrapped up around the wheel. Otherwise the spring in the wheel may be totally loose, and will not coil.
    • Carefully put the button into its hole. It should stick out over the little curved groove, over the wires. Check that it turns the dimmer and clicks the on-off push button.
Sonuç
To reassemble your device, follow these instructions in reverse order until step 6: reassembly of this step is shown in step 10.
Bir başkası bu kılavuzu tamamladı.
Elisabeth Kvaalen
211 İtibar
1 Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 7
Son 30 gün: 22
Her zaman: 1,613
