Ana içeriğe geç
Bose SoundLink Mini Front/Back Protective Grille Replacement
Jordan Smith
Jordan Smith ve 4 diğer katkıda bulunanlar
En son February 2, 2023 tarihinde güncellendi
5 dakika
Orta
Use this guide to replace the front or back mesh grilles. Make sure you have the required tools. The first time you remove a grille might be a little difficult due to some glue holding it in place. Be careful when removing, as the grille may bend easily.
Neye ihtiyacın var
Aletler
  1. Bose SoundLink Mini Front/Back Protective Grille Replacement, Front/Back Protective Grille: adım 1, 1 resimden 1.
    • Insert the Metal Spudger between the rubber edge on the grille and the aluminum casing.
    • Place Metal Spudger in the location shown.
    Woher bekomme ich nun rin solches Vorder- und Rückgitter?
    [COBS]CR4ZY BLITZ - Yanıt
  2. Bose SoundLink Mini Front/Back Protective Grille Replacement: adım 2, 2 resimden 1. Bose SoundLink Mini Front/Back Protective Grille Replacement: adım 2, 2 resimden 2.
    • Slowly pry up the grille until the two tabs shown pop out.
    • Be very gentle, the grille will bend.
  3. Bose SoundLink Mini Front/Back Protective Grille Replacement: adım 3, 2 resimden 1. Bose SoundLink Mini Front/Back Protective Grille Replacement: adım 3, 2 resimden 2.
    • The grille is attached to the speaker with double sided sticky tape. To remove the grill gently pull upward while keeping tension to the right.
  4. Bose SoundLink Mini Front/Back Protective Grille Replacement: adım 4, 2 resimden 1. Bose SoundLink Mini Front/Back Protective Grille Replacement: adım 4, 2 resimden 2.
    • Repeat steps to remove the back grille.
    Attention à la longueur des vis (les 4 vis du côté du circuit sont les 4 plus longue) et si vous vous trompez et plaçez ces 4 vis ailleurs vous risquez de les briser et que le bout de celles-ci demeurera dans la partie du chassis.
    Pierre Payette - Yanıt
Sonuç
10 farklı kişi bu kılavuzu tamamladı.
Jordan Smith
917 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 1-23, Maness Fall 2015 Cal Poly, Team 1-23, Maness Fall 2015 üyesi
CPSU-MANESS-F15S1G23
4 Üyeler
21 adet Kılavuz yazıldı
6Kılavuz Yorumları
Has anyone an idea where to buy new meshs for the dark version of Bose SL II ? My are badly scratched and I'd like to replace them.. dont know where to buy them though..
krisskuli - Yanıt
Hi brilliant advise. Where can I get hold of the front perl white grill? I can't find it anywhere!
Peter Bacher - Yanıt
Hi brilliant advise. Where can I get hold of the front perl white grill of my soundlink mini ? I can't find it anywhere!
Where can I purchase the grill?
Ronald Roden Jr - Yanıt
Take out the grills, put a peace of tape on logo properly cut it, and repaint it. Apply a thin coat of spray paint only.
Pranjal Vishwakarma - Yanıt
Steps are wrong and difficult. Try taking out from somewhere between the center, it will automatically pull the locks out which are located on the sides.
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 23
Son 30 gün: 109
Her zaman: 13,620
