Ana içeriğe geç
Bose SoundLink Mini II Audio Port/USB Replacement
Neye ihtiyacın var
  1. Bose SoundLink Mini II Audio Port/USB Replacement, Battery: adım 1, 2 resimden 1. Bose SoundLink Mini II Audio Port/USB Replacement, Battery: adım 1, 2 resimden 2.
    • Flip the speaker over onto its back.
    FixBot'a Sor
    Yorum Ekle
  2. Bose SoundLink Mini II Audio Port/USB Replacement, Remove the rubber base: adım 2, 2 resimden 1. Bose SoundLink Mini II Audio Port/USB Replacement, Remove the rubber base: adım 2, 2 resimden 2.
    • Gently remove the rubber base from speaker by pulling around the edges.
    FixBot'a Sor
    Yorum Ekle
  3. Bose SoundLink Mini II Audio Port/USB Replacement: adım 3, 2 resimden 1. Bose SoundLink Mini II Audio Port/USB Replacement: adım 3, 2 resimden 2.
    • Remove the four 6mm T9 Torx bit screws from the corners of the battery.
    FixBot'a Sor
    Yorum Ekle
  4. Bose SoundLink Mini II Audio Port/USB Replacement: adım 4, 3 resimden 1. Bose SoundLink Mini II Audio Port/USB Replacement: adım 4, 3 resimden 2. Bose SoundLink Mini II Audio Port/USB Replacement: adım 4, 3 resimden 3.
    • Carefully lift the battery from the side nearest the four gold contact pins, but don't try to fully remove it yet.
    • At this point, the battery remains connected via four wires to the power supply board.
    • Carefully desolder the four wires from the power supply board in order to completely detach the battery. There is very little room for the soldering iron without damaging the case or the board; you may want to remove the board first.
    • For help with soldering, see the soldering guide.
    • Alternatively, you may remove the battery and power supply board together, without any soldering, but access requires some additional disassembly while carefully leaving the battery connected via the wires the entire time.
    FixBot'a Sor
    Yorum Ekle
  5. Bose SoundLink Mini II Audio Port/USB Replacement, Bose Technicians' Instruction Manual: adım 5, 1 resimden 1.
    FixBot'a Sor
    Yorum Ekle
  6. Bose SoundLink Mini II Audio Port/USB Replacement, Audio Port/USB Circuit Board: adım 6, 1 resimden 1.
    • With the battery removed the button board will now be visible.
    FixBot'a Sor
    Yorum Ekle
  7. Bose SoundLink Mini II Audio Port/USB Replacement: adım 7, 3 resimden 1. Bose SoundLink Mini II Audio Port/USB Replacement: adım 7, 3 resimden 2. Bose SoundLink Mini II Audio Port/USB Replacement: adım 7, 3 resimden 3.
    • Remove the rear grille using the metal spudger.
    • The grille bends and deforms easily.
    FixBot'a Sor
    Yorum Ekle
  8. Bose SoundLink Mini II Audio Port/USB Replacement: adım 8, 3 resimden 1. Bose SoundLink Mini II Audio Port/USB Replacement: adım 8, 3 resimden 2. Bose SoundLink Mini II Audio Port/USB Replacement: adım 8, 3 resimden 3.
    • Remove the eight 9mm T9 Torx screws from the circuit board and back panel.
    • Use a metal spudger to release the ribbon cable connector and remove cable from the audio/USB board.
    FixBot'a Sor
    Yorum Ekle
Sonuç
14 farklı kişi bu kılavuzu tamamladı.
Devon
545 İtibar
2 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 5-2, Passmore Spring 2017 USF Tampa, Team 5-2, Passmore Spring 2017 üyesi
USFT-PASSMORE-S17S5G2
4 Üyeler
19 adet Kılavuz yazıldı
1Rehber Yorum
Where did you get the replacement part?
Viesturs Rauza - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 6
Son 7 gün: 48
Son 30 gün: 181
Her zaman: 23,786
