Ana içeriğe geç
Bose SoundLink Mini II Speaker Replacement
Neye ihtiyacın var
  1. Bose SoundLink Mini II Speaker Replacement, Battery: adım 1, 2 resimden 1. Bose SoundLink Mini II Speaker Replacement, Battery: adım 1, 2 resimden 2.
    • Flip the speaker over onto its back.
    If the blinking red battery is the reason to change the battery, first try reinstalling the latest firmware via Bose.
    When the site tells you that you already have the latest version, just press A, then D, then V, then the up arrow and last the down arrow. The option to reinstall the latest firmware will appear. Just reinstall it and that might fix your battery. It did for me and saved me a new battery.
    Harm Jan Berendsen - Yanıt
  2. Bose SoundLink Mini II Speaker Replacement, Remove the rubber base: adım 2, 2 resimden 1. Bose SoundLink Mini II Speaker Replacement, Remove the rubber base: adım 2, 2 resimden 2.
    • Gently remove the rubber base from speaker by pulling around the edges.
    Das Fehlerbild das ich beobachtet habe, war ein kontinuierliches rotes blinken der Power LED. Der Akku wurde nicht mehr geladen. Empfehlungen das Gerät in der ship mode zu versetzen um dann zu laden waren erfolglos. Nach dem Akku tauschen das gleiche verhalten. Die SW war auf dem aktuellen Stand.
    Die Lösung war am Ende eine komplette neu Installationen der SW.
    Dazu auf die böse sw Update Seite gehen und dann die Tasten "Page Up" und dann "Page down" drücken. Dan wird die Option angeboten, die gleiche SW nochmals zu installieren. Danach war alles funktionsfähig.
    Andreas - Yanıt
  3. Bose SoundLink Mini II Speaker Replacement: adım 3, 2 resimden 1. Bose SoundLink Mini II Speaker Replacement: adım 3, 2 resimden 2.
    • Remove the four 6mm T9 Torx bit screws from the corners of the battery.
    Not sure what’s going on here but T9 is the wrong size—too big—for the screws on my SoundLink Mini II. Maybe T8? Perhaps my model is more recent and they’ve changed sizes? I bought the screwdriver from IFIXIT following these instructions, so I’m a *bit* annoyed…
    David Whitley - Yanıt
    That’s really frustrating. I’ve seen this before, where manufacturers swap screws and other components without changing the model number. I have a 64 bit driver set from iFixit, but I don’t recall which bit I used for this. The screws in my one are different lengths to the ones in the original instructions.
    Kate Morris -
  4. Bose SoundLink Mini II Speaker Replacement: adım 4, 3 resimden 1. Bose SoundLink Mini II Speaker Replacement: adım 4, 3 resimden 2. Bose SoundLink Mini II Speaker Replacement: adım 4, 3 resimden 3.
    • Carefully lift the battery from the side nearest the four gold contact pins, but don't try to fully remove it yet.
    • At this point, the battery remains connected via four wires to the power supply board.
    • Carefully desolder the four wires from the power supply board in order to completely detach the battery. There is very little room for the soldering iron without damaging the case or the board; you may want to remove the board first.
    • For help with soldering, see the soldering guide.
    • Alternatively, you may remove the battery and power supply board together, without any soldering, but access requires some additional disassembly while carefully leaving the battery connected via the wires the entire time.
    cuanto tiempo dura la bateria original ?
    Marcelo Lastra - Yanıt
    the mini 2 battery is soldered to a smaller board, either u desolder it or buy it with the small board, but with that it is even harder to replace
    user user - Yanıt
    Yeah this guide is just like the original Bose Mini which looked like that model had a way to replace the batter easily. I purchased a battery off Amazon thinking it was the same. This is not the same. The Bose Mini II has a battery hard-wired directly to the board. Might be too late but read this guide’s comments first to get the low down. The guide is very misleading. The BOSE SOUNDLINK MINI II **DOES NOT HAVE A REPLACEABLE BATTERY**
    Ian Lucero - Yanıt
    yess, got the same problem. Purchased an substitute which had as Replacement No. the original Bose-No. on its description. Bose’s accu has 4 strings, the replacement has 5 strings (where to put the fifth then?!).
    Original we had to CUT OFF, because it is firmly soldered and glued with foam! No chance to replace it!! Nearly 60.- Swiss Francs as we say “for the foxes”.
    Maranathatalitha -
    DO NOT buy a replacement battery until you understand that the battery is HARD WIRED to the circuit board and is NOT designed to be replaceable. If you are not an electronics specialist, the only option is to send to Bose for battery replacement.
    Even if you are an electronics specialist, finding a replacement battery may not be possible.
    ldthom65 - Yanıt
    I am very glad I took the time to review everything and all the comments before I started this procedure on my Soundlink Mini 2.
    I have to say, the author of this procedure is a pathetic jerk for posting this and not distinguishing the between the 1 and 2 versions. It is also highly suspect that there is no clear picture of the top of the unit, which would indicate which version is being used due to the fact that the 2 has no mute button.
    trmsd - Yanıt
    Hey du hole Frucht, die Bose Soundlink 1 hat keine Kabel an der Batterie, nur die Soundlink Mini 2 hat Kabel die auf die Platine gelötet werden muss!
    Ihr Affen habt doch keine Ahnung!
    Und den Bose Schriftzug muss der Autor nicht zeigen, wegen der Rechtlichen Lage in Deutschland!
    r.janda -
    It’s disappointing, for sure. But to call the author, who’s been kind enough to post this without getting anything in return, a pathetic jerk is waaay over the top! Come on. If anyone deserves abuse, then it’s Bose for producing a speaker with a battery that’s totally and easily replaceable except they decided to solder it onto the circuit board for some unfathomable reason. Argh!
    B. J. - Yanıt
    I suspect that the soldering the battery directly to the power board is a way to enhance revenue because most people will either send it in to be replaced or throw it away and buy another speaker. Of course Bose hopes that the replacement will be another Bose, but that is not likely for anyone who is frustrated by the idea that Bose would not make the battery easily replaceable.
    wannabagolfer - Yanıt
    Absolutely. Great I checked up first. I will not buy any other rechageable battery operated Bose product. It is clear customer abuse. The same should go to companies like Samsung which produces cellular phones with practically embedded impossible to replace without risking breaking the cristal. Customer protection in this country unfortunately has gone away with lobby. (Legalization Of Bureaucratic BriberY) Same with Apple and then Microsoft when they do updates and then no longer support an OS that could be still useful for the needs of certain people or businesses
    Dario Grisales - Yanıt
    ………..just bought a replacement battery based upon ifixit’s original post. This is neither a 5 minute two wire push fit job NOR one for an amateur to attempt. I now have a box of BOSE bits and spare unsuable battery.
    Thanks pal.
    Beware of internet advice
    Richard Brickwood - Yanıt
    ……..just bought (£30) a replacement battery based up ifixit’s orginal post that it was a)simple and b)took 5 minutes only to discover that a) there are four wires involved hard solderied to a pcb. Spent an hour undoing torc screws to dismantel the whole thing. It is not possible.
    I now have abox of BOSE bits and a brand new unuseable battery. And no speaker.
    Shame on both BOSE and ifixit - the latter for being so misleading .
    I’m pretty disappointed with ifixit on this one! I feel bad giving you guys a bad review but this one is just bad! It’s Missing steps, it’s labelled as easy when it certainly shouldn’t be. iPhone battery’s are easy. This requires awkward desoldering/soldering. In a tight spot. There’s not even a mention of that in this guide? Maybe someone could rewrite this so others don’t go and purchase a battery thinking it’s easy!
    Wiebie - Yanıt
    The instructions are not complete, and I needed extra information to replace the battery on my soundlink mini 2. I successfully completed the battery replacement using instructions I found by searching for SLminiII_SM.pdf. That document describes the steps Bose technicians take. With that, it took about 30 minutes to replace the battery. I removed the board the battery is soldered to, which made it an easy soldering job (four through-hole wires, no SMT). I carefully saved and replaced the foam tape because the last thing you want in a speaker is buzzing sounds due to the wiring rubbing against the speaker. If you’ve already bought the parts, and have access to a soldering iron. I’d recommend searching for the instructions I used.
    Kate Morris - Yanıt
    I was not able to find that document. Do you have any tips for finding it and I was wondering if you bought your replacement battery from ifixit or if you have any recommendations for where you bought yours.
    Michael Calaiaro -
    The instructions are at https://riverparkinc.com/wp-content/uplo... . I bought this battery from Amazon: https://www.amazon.com/gp/product/B08FHX... (not an affiliate link). The speaker is working fine and charging, a few months later.
    Kate Morris -
    Thank you very much
    daniel -
    I tried to follow these instructions. I cannot find where to download the 'Polycomm' software necessary to reset the hardwire between chip and battery. I've trawled all over the internet and Bose's own websites. Could some one please advise?
    Christie Dunne Murphy -
    I would like to measure the voltage of the battery before replacing it, does anyone know which one of the 4 wires is power or ground?
    Akash Arora - Yanıt
    Playing with a soldering iron and live li-on battery leads ?
    A good way to burn the place to the ground !
    cricri - Yanıt
    I have a box of SoundLink parts.
    That Polycomm software has got to be out there somewhere! Anybody?
    Does anyone have a copy of this software tool.
    Aaron V. - Yanıt
    You don't need the Polycomm software, you just need to reinstall the Firmware even if it's up-to-date. Got to https://btu.bose.com/ and plug the speaker in and update. It may say it's up to date, but if you type A, D, V, Up Arrow & Down Arrow it lets you into advance mode and you can force the firmware to be reinstalled
    James Pither - Yanıt
    Kudos James!
    You held the secret to finishing this up! Pressing A, D, V, Up Arrow & Down Arrow in sequence after getting the updater going at https://btu.bose.com/ , then updating the firmware got the job done. Before doing this my power light just blinked red when trying to charge and the speaker The physical replacement was no big deal. I bought a replacement battery from amazon or ebay, I don't remember where, and instead of de-soldering the battery from the power supply board, because I suck a soldering, I cut off the old battery real short and spliced the new battery into the wires still hanging from the power supply. Lots of whining about the hardwired battery but I think I understand the decision Bose made in doing it. This little speaker booms, and the last thing they wanted was a loose battery connector rattling around. The fact that they aren't suing me for fixing it, even thought it takes a little thought and effort to do so, at least keeps them above John Deere, Tesla, etc., in my eyes.
    TMS -
    So, is there anything I can do when even the Bose Updater doesnˋt recognize my Mini 2? Have the Updater installed, cable plugged in but nothing happens. Except for the red blinking.
    Oliver Wiebeck - Yanıt
    Hi James, TMS, My battery has just stopped charging. I have a Bose which has stopped charging. I came across a youtube video suggesting it could be that the battery has gone into "Battery Protection Mode" I followed the suggestions provided in the video but without results. Before the video ends the guy suggests a firmware up-date. Is it obvious what A, D, V, Up Arrow & Down Arrow in sequence means when up-dating? Don't suppose there's a youtube video showing this procedure is there?!
    Charlie Watson - Yanıt
  5. Bose SoundLink Mini II Speaker Replacement, Bose Technicians' Instruction Manual: adım 5, 1 resimden 1.
  6. Bose SoundLink Mini II Speaker Replacement, Speaker: adım 6, 2 resimden 1. Bose SoundLink Mini II Speaker Replacement, Speaker: adım 6, 2 resimden 2.
    • Removing the device front grille with a metal spudger, starting in one corner and working around the border.
    • The grille is easily bent and deformed.
    The speaker grilles have foam tape. The shop manual suggest dissolving the glue with alcohol to avoid destroying the foam tape.
    Kate Morris - Yanıt
  7. Bose SoundLink Mini II Speaker Replacement: adım 7, 3 resimden 1. Bose SoundLink Mini II Speaker Replacement: adım 7, 3 resimden 2. Bose SoundLink Mini II Speaker Replacement: adım 7, 3 resimden 3.
    • Remove the rear grille with a metal spudger, starting in one corner and working around the border.
    Ich habe einen Ersatzakku gekauft, dieser hat aber jetzt einen Steckerteil mit 5 Anschlüssen, der alte Akku aber nur 4.
    Ich habe wieder 4 Kabel an die Platine gelötet. Wie muss der 5. Anschlusspunkt am Akku verbunden werden? Eine Antwort würde mich freuen!
    Danke, Karle
    Karlhans Schwarz - Yanıt
    I recommend starting in the middle of one of the long sides and working outward, then doing the same with the other side. There are two strips of foam tape, about 2” long, at the centers of the long sides. The foam tape either needs to be cut or detached to remove the grille. The short sides are held on by tabs which must be released by bowing the center of the grille outward. Before reattaching, it’s helpful to put a slight inward bow into the grille, but to then seat the outer tabs before seating the center.
    Christopher Dickey - Yanıt
  8. Bose SoundLink Mini II Speaker Replacement: adım 8, 2 resimden 1. Bose SoundLink Mini II Speaker Replacement: adım 8, 2 resimden 2.
    • Remove the eight 9mm T9 screws.
    For the model I have, the four screws on the left hand side were 15mm not 9mm.
    Kate Morris - Yanıt
  9. Bose SoundLink Mini II Speaker Replacement: adım 9, 2 resimden 1. Bose SoundLink Mini II Speaker Replacement: adım 9, 2 resimden 2.
    • Use the metal spudger to release ribbon cable retainer.
    • Detach the ribbon cable from the circuit board by sliding out from board connector.
    This is the step I am unsure of. Could you add a better picture or more information? Does the ribbon cable connector clip in, or simply slide in? The foam that covers the cable hides some detail here.
    Kate Morris - Yanıt
    Updating my comment: I searched for SLminiII_SM.pdf and found more detailed instructions, which helped me complete the repair.
    Kate Morris - Yanıt
    The black strip on the connector lifts from the back side of the connector and then the ribbon cable just slips out.
    Tracey Jackson - Yanıt
  10. Bose SoundLink Mini II Speaker Replacement: adım 10, 3 resimden 1. Bose SoundLink Mini II Speaker Replacement: adım 10, 3 resimden 2. Bose SoundLink Mini II Speaker Replacement: adım 10, 3 resimden 3.
    • Pull the ribbon cable through the rear case wall.
    This step is not necessary if all you are doing is replacing the battery (if you want to do a complete tear-down, go ahead!).
    Kate Morris - Yanıt
    It is easier to slide the cable out through the slot if the barbs on the cable grommet (the gray rubber piece at the base of the cable) are first pushed through the slot with a spudger.
    During this step I ended up ripping the ribbon cable connector from the control board below the back plate. Do not try to remove the back panel from the connector side. The connector side MUST not be lifted while removing the back panel. Not sure where to go from here. The cable connector is destroyed. I will have to solder a new connector or buy a new control board.
  11. Bose SoundLink Mini II Speaker Replacement: adım 11, 3 resimden 1. Bose SoundLink Mini II Speaker Replacement: adım 11, 3 resimden 2. Bose SoundLink Mini II Speaker Replacement: adım 11, 3 resimden 3.
    • Remove the top circuit board by lifting up.
    • Disconnect the wired pair from board upon removal.
    • There is a non latched connector connecting the top board to side board. Be careful to not damage this connector during the removal process.
  12. Bose SoundLink Mini II Speaker Replacement: adım 12, 2 resimden 1. Bose SoundLink Mini II Speaker Replacement: adım 12, 2 resimden 2.
    • Remove the power supply board by sliding it outward from the device.
    • This is the board that was previously soldered to the battery.
    • There is a non latched connector connecting the side board to button board. Be careful to not damage this connector during the removal process.
    If all you are doing is replacing the battery, you don’t need the following steps. Desolder the old battery from the board, solder the new one in, and reverse the steps to reassemble. Save and re-use the foam tape to prevent buzzing.
    Kate Morris - Yanıt
  13. Bose SoundLink Mini II Speaker Replacement: adım 13, 2 resimden 1. Bose SoundLink Mini II Speaker Replacement: adım 13, 2 resimden 2.
    • Remove the eight 9mm T9 Torx screws from the front of the device.
  14. Bose SoundLink Mini II Speaker Replacement: adım 14, 3 resimden 1. Bose SoundLink Mini II Speaker Replacement: adım 14, 3 resimden 2. Bose SoundLink Mini II Speaker Replacement: adım 14, 3 resimden 3.
    • Use the metal spudger to remove the front case panel.
  15. Bose SoundLink Mini II Speaker Replacement: adım 15, 2 resimden 1. Bose SoundLink Mini II Speaker Replacement: adım 15, 2 resimden 2.
    • Remove the speakers from the case.
Sonuç
19 farklı kişi bu kılavuzu tamamladı.
Tyler Roessler
1.562 İtibar
1 Kılavuz yazıldı
Ekip
USF Tampa, Team 5-2, Passmore Spring 2017 USF Tampa, Team 5-2, Passmore Spring 2017 üyesi
USFT-PASSMORE-S17S5G2
4 Üyeler
19 adet Kılavuz yazıldı
10Kılavuz Yorumları
Anyone know where to find the speaker for replacement?
Matthew - Yanıt
Die Anleitung ist Fehlerhaft! Der Akku ist im SLM2 Festgelötet, in der Anleitung kein Wort davon und auch die Bilder sind damit Falsch.
Robert - Yanıt
(englisch version below)
Scheinbar eine Verwirrung, es gibt verschiedene Ausführungen des selben Models. Es scheint als sie im amerikanischen die Soundlink mini 2 mit steckbaren Akku verkauft worden und die gelötete in Europa.
It seems there is some confusion ongoing, there are different versions of the same model. It seems likely in Amerika the Soundlink mini 2s battery is unplugable, as the european version is soldered.
Raphael Krug -
Nachtrag! Das ist die Anleitung vom Mini 1 und somit Falsch Deklariert.
Robert - Yanıt
The German guy (Robert) seems incorrect. He claims this teardown is for the original Bose MiniSoundlink I. I just confirmed it is indeed a teardown for Bose Mini Soundlink II by checking the model number of my own Soundlink II with the teardown photos showing the model number (in steps 3 & 4). Both show model number 088796., confirming this is Soundlink II.
Jason - Yanıt
Hi all.
One of the speakers of my soundlink mini II is malfunctioning (rattling/buzzing) due to (let us say) vandalism. Is there any place where I could purchase the replacement for the speaker?. I am in Spain and I can not find it. Thanks !
porrinchas - Yanıt
How do you repair the press button on and off it has warned out. No longer cutting on or off due to the rubber switch wear and tear
Bernadette Everette - Yanıt
Anyone know where can I get a shell and grill replacement part for my soundlink mini 2? I want to replace the shell and the grill of my soundlink mini 2.
Hadrian Wong - Yanıt
Hi all,
instead of removing the parts in order to replace the cable I would recommend to unsolder the speakers from the cables and solder the new ones.
What do you think?
2ch - Yanıt
Hi all,
while changing the speakers I learned that the cables are not soldered but wrapped around the contacts. However, they can easily be soldered which seems to me recommended. Works perfectly and spares time.
2ch - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 12
Son 7 gün: 93
Son 30 gün: 486
Her zaman: 54,174
