Ana içeriğe geç
Bose Soundlink Revolve Speaker Replacement
Neye ihtiyacın var
  1. Bose Soundlink Revolve Speaker Replacement, Speaker: adım 1, 1 resimden 1.
    • Use a plastic opening tool or metal spudger to remove the rubber mount from the bottom of the speaker.
  2. Bose Soundlink Revolve Speaker Replacement: adım 2, 1 resimden 1.
    • Use a T10 screwdriver to remove the three 10 mm screws from the bottom of the speaker.
  3. Bose Soundlink Revolve Speaker Replacement: adım 3, 1 resimden 1.
    • Unhook the ribbon conector that connects the bottom cover to the body, then remove the bottom part of the speaker.
  4. Bose Soundlink Revolve Speaker Replacement: adım 4, 1 resimden 1.
    • Use a TR9 screwdriver to remove the screws from the top of the speaker, and then remove the top part of the speaker along with the motherboard.
  5. Bose Soundlink Revolve Speaker Replacement: adım 5, 1 resimden 1.
    • Slide the body of the speaker from the metal cover.
  6. Bose Soundlink Revolve Speaker Replacement: adım 6, 1 resimden 1.
    • Use a T10 screwdriver to remove the four 6 mm screws around the 2 speakers, and remove the speaker units from the body.
  7. Bose Soundlink Revolve Speaker Replacement: adım 7, 1 resimden 1.
    • Pull off the metal case from the speaker body.
  8. Bose Soundlink Revolve Speaker Replacement: adım 8, 1 resimden 1.
    • Remove the three 25.3mm screws from the bottom part of the speaker body with a T10 Torx screwdriver.
  9. Bose Soundlink Revolve Speaker Replacement: adım 9, 1 resimden 1.
    • Use a spudger to pry apart the glued section between the speaker panel and the device.
  10. Bose Soundlink Revolve Speaker Replacement: adım 10, 1 resimden 1.
    • Open the speaker panel, then unwind the three wires from the speaker.
  11. Bose Soundlink Revolve Speaker Replacement, Speaker: adım 11, 1 resimden 1.
    • Remove the four 6 mm screws from the top part of the speaker body using a T10 screwdriver.
  12. Bose Soundlink Revolve Speaker Replacement: adım 12, 1 resimden 1.
    • Remove the speakers from the device.
Sonuç
11 farklı kişi bu kılavuzu tamamladı.
Claire Alte
40 İtibar
1 Kılavuz yazıldı
Ekip
IUPUI, Team S1-G1, Wilson Spring 2019 IUPUI, Team S1-G1, Wilson Spring 2019 üyesi
IUPUI-WILSON-S19S1G1
3 Üyeler
6 adet Kılavuz yazıldı
9 Yorum
Hi,
I buy used revolve and change top board, battery, cable… everything working good but when you play music I hear some “vibrations” from speaker. Main speaker is ok when playing out of hausing. When I remove speaker from side (step11 of this page) vibration is gone out. If I put speaker on place vibrations is come. Do you have any idea what can causing this problem please?
M.
Martin - Yanıt
Hi Martin,
Same issue on my side. The vibrations (especially for the basses) come from an air gap. You have to be very careful when you reassemble the device, especially for the speaker. I had have to replace the foamed tape.
Hope this will help
Olivier
Olivier -
Saya punya speaker serupa
Kendalanya dicas hanya menyala lampu indikator kuning terus dan speaker mati total
Bagaimana cara mengatasinya
susanto santo - Yanıt
My experience is that the side speakers should seal properly otherwise the sound is distorted. Rupture on the membrane allowed an air stream coming out which is directly related to the distorted sound especially at the bass. I used Billy Ellish Bad Guy as a reference. I identified the side speaker to my local Bose service (BaSys, Hungary, thx) via the image in this description. They brought me a pair of speakers for~15eur in two weeks. On the package stands 357793-0010 which is probably the part number. I did the replacement according to the description with success.
katonage - Yanıt
can anyone tell me where to get a replacement base speaker for my soundlink resolve
brucered69 - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 20
Son 30 gün: 119
Her zaman: 14,221
