Ana içeriğe geç
Bose Soundlink Revolve Speaker Replacement
Neye ihtiyacın var
  1. Bose Soundlink Revolve Speaker Replacement, Speaker: adım 1, 1 resimden 1.
    • Use a plastic opening tool or metal spudger to remove the rubber mount from the bottom of the speaker.
  2. Bose Soundlink Revolve Speaker Replacement: adım 2, 1 resimden 1.
    • Use a T10 screwdriver to remove the three 10 mm screws from the bottom of the speaker.
    This is not a T10 screwdriver at all... T10 have 6 branch star...bose screw have only 5...
    Martin - Yanıt
  3. Bose Soundlink Revolve Speaker Replacement: adım 3, 1 resimden 1.
    • Unhook the ribbon conector that connects the bottom cover to the body, then remove the bottom part of the speaker.
  4. Bose Soundlink Revolve Speaker Replacement: adım 4, 1 resimden 1.
    • Use a TR9 screwdriver to remove the screws from the top of the speaker, and then remove the top part of the speaker along with the motherboard.
    What screw are we removing here?
    andrewpalozzo - Yanıt
  5. Bose Soundlink Revolve Speaker Replacement: adım 5, 1 resimden 1.
    • Slide the body of the speaker from the metal cover.
  6. Bose Soundlink Revolve Speaker Replacement: adım 6, 1 resimden 1.
    • Use a T10 screwdriver to remove the four 6 mm screws around the 2 speakers, and remove the speaker units from the body.
  7. Bose Soundlink Revolve Speaker Replacement: adım 7, 1 resimden 1.
    • Pull off the metal case from the speaker body.
  8. Bose Soundlink Revolve Speaker Replacement: adım 8, 1 resimden 1.
    • Remove the three 25.3mm screws from the bottom part of the speaker body with a T10 Torx screwdriver.
  9. Bose Soundlink Revolve Speaker Replacement: adım 9, 1 resimden 1.
    • Use a spudger to pry apart the glued section between the speaker panel and the device.
  10. Bose Soundlink Revolve Speaker Replacement: adım 10, 1 resimden 1.
    • Open the speaker panel, then unwind the three wires from the speaker.
    From where I can get mother board and fct cable
    Ghanshayam verma - Yanıt
  11. Bose Soundlink Revolve Speaker Replacement, Speaker: adım 11, 1 resimden 1.
    • Remove the four 6 mm screws from the top part of the speaker body using a T10 screwdriver.
    Where can I get this bass diaphragm passive radiator I’ve been searching for a long time and I can’t find one that fits the Bose revolve, mine is old now and it has started tearing now air escapes when I play music.
    For The hub - Yanıt
  12. Bose Soundlink Revolve Speaker Replacement: adım 12, 1 resimden 1.
    • Remove the speakers from the device.
Sonuç
11 farklı kişi bu kılavuzu tamamladı.
Claire Alte
40 İtibar
1 Kılavuz yazıldı
Ekip
IUPUI, Team S1-G1, Wilson Spring 2019 IUPUI, Team S1-G1, Wilson Spring 2019 üyesi
IUPUI-WILSON-S19S1G1
3 Üyeler
6 adet Kılavuz yazıldı
9Kılavuz Yorumları
Hi,
I buy used revolve and change top board, battery, cable… everything working good but when you play music I hear some “vibrations” from speaker. Main speaker is ok when playing out of hausing. When I remove speaker from side (step11 of this page) vibration is gone out. If I put speaker on place vibrations is come. Do you have any idea what can causing this problem please?
M.
Martin - Yanıt
Hi Martin,
Same issue on my side. The vibrations (especially for the basses) come from an air gap. You have to be very careful when you reassemble the device, especially for the speaker. I had have to replace the foamed tape.
Hope this will help
Olivier
Olivier -
Saya punya speaker serupa
Kendalanya dicas hanya menyala lampu indikator kuning terus dan speaker mati total
Bagaimana cara mengatasinya
susanto santo - Yanıt
My experience is that the side speakers should seal properly otherwise the sound is distorted. Rupture on the membrane allowed an air stream coming out which is directly related to the distorted sound especially at the bass. I used Billy Ellish Bad Guy as a reference. I identified the side speaker to my local Bose service (BaSys, Hungary, thx) via the image in this description. They brought me a pair of speakers for~15eur in two weeks. On the package stands 357793-0010 which is probably the part number. I did the replacement according to the description with success.
katonage - Yanıt
can anyone tell me where to get a replacement base speaker for my soundlink resolve
brucered69 - Yanıt
Step 11 for reference.
Where can I get this bass diaphragm passive radiator, haven’t been able to find one that fits the speaker.
For The hub - Yanıt
I have the same disorted bass radiator problem, where can i get the bass radiators?
Kelpo Johny - Yanıt
This is very helpful. Mine won't charge with a cable or the base. Should I replace the charging port piece & the battery at same time? Where do I buy materials?. Any help is very welcomed. TY.
Liz Murphy - Yanıt
I get that sound with my base I thought the speaker blew. Can I check if it may be just a the speaker vibrations (especially for the basses). Where might replace parts only finding charging pads.
Ben Ryer - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 24
Son 30 gün: 142
Her zaman: 14,280
