Ana içeriğe geç
Bowers and Wilkins T7 Battery Replacement
Neye ihtiyacın var
  1. Bowers and Wilkins T7 Battery Replacement, Access Panel: adım 1, 1 resimden 1.
    • As with all electronic devices, make sure your device is powered off before you begin.
    • Gently lift up the access panel; it should easily "pop" open.
    My model does not have screws in the front as indicates here. Not sure what to do now
    thebolts - Yanıt
  2. Bowers and Wilkins T7 Battery Replacement: adım 2, 1 resimden 1.
    • Remove 14mm screws on the front panel with a J1 Phillips head screwdriver.
    • There are 8 screws in total.
    FYI: I bought the Ifixit toolkit and sadly the screw driver isn’t long enough to remove the 4 middle screws.
    Jonathan Keay - Yanıt
    What sizes are the screws exactly? I took mine apart and someone threw out the screws so now I need replacements.
    Pablo Escobar - Yanıt
  3. Bowers and Wilkins T7 Battery Replacement: adım 3, 2 resimden 1. Bowers and Wilkins T7 Battery Replacement: adım 3, 2 resimden 2.
    • Be gentle, the rubber seal is fragile and easy to tear, resulting in cosmetic damage to your device.
    • Using the ifixit Opening Tool, carefully pry off the rubber seal around the sides.
    • The seal is held by adhesive, if this is proving difficult you can use a heat gun to help the process.
  4. Bowers and Wilkins T7 Battery Replacement: adım 4, 2 resimden 1. Bowers and Wilkins T7 Battery Replacement: adım 4, 2 resimden 2.
    • The cover is the most difficult part to remove. As you work, pry continuously, moving the tool around the device, working it a little further as you go.
    • Using the ifixit Opening Tool, pry open at the seam found under the rubber seal.
    • As the cover starts to come off, you can lift up using your hand.
    I tried this with the ifixit tool, but I could not remove the cover
    m6rtg - Yanıt
    I used a sharp knife. Note carefully where the seam is in the above diagram: on the back about 7 mm from the edge.
    al.germain - Yanıt
  5. Bowers and Wilkins T7 Battery Replacement: adım 5, 3 resimden 1. Bowers and Wilkins T7 Battery Replacement: adım 5, 3 resimden 2. Bowers and Wilkins T7 Battery Replacement: adım 5, 3 resimden 3.
    Bu adımda kullanılan alet:
    • Gently squeeze the internal locking mechanism inside the red and white terminals with either your fingers or a pair of precision tweezers.
    • While squeezing the internal locking mechanism, pull back the terminal.
    • Repeat this process for the second speaker.
  6. Bowers and Wilkins T7 Battery Replacement, Battery: adım 6, 1 resimden 1.
    • Using a cutting tool such as a Jimmy steel blade or wire cutter, cut the cable tie surrounding the battery.
    • Be careful not to damage the battery while cutting the cable tie surrounding the battery.
  7. Bowers and Wilkins T7 Battery Replacement: adım 7, 2 resimden 1. Bowers and Wilkins T7 Battery Replacement: adım 7, 2 resimden 2.
    • Using the ifixit Opening Tool, pry out the battery power supply connector.
    • Pull and remove the battery power supply connector.
  8. Bowers and Wilkins T7 Battery Replacement: adım 8, 2 resimden 1. Bowers and Wilkins T7 Battery Replacement: adım 8, 2 resimden 2.
    • After disconnecting the power supply connector, pull the battery out of its case.
    So, how do you install the new battery? Where do you get a new battery for this speaker?
    Kevin - Yanıt
Sonuç
9 farklı kişi bu kılavuzu tamamladı.
Bertrand Plummer
269 İtibar
1 Kılavuz yazıldı
Ekip
USF Tampa, Team S7-G1, Cagle Spring 2017 USF Tampa, Team S7-G1, Cagle Spring 2017 üyesi
USFT-CAGLE-S17S7G1
5 Üyeler
6 adet Kılavuz yazıldı
3Kılavuz Yorumları
Bravo ! Le choix de cet appareil symbolique !
Pierre Vanhoorenbeeck - Yanıt
Seriously
Couldn't the lady get her
'nails did’
Lux Valet - Yanıt
No repair any repairing sentar
Abdul Malik Parvez - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 26
Son 30 gün: 138
Her zaman: 10,777
