Ana içeriğe geç
Braun 5514 Motor Replacement
Andrew Kluckhuhn
Andrew Kluckhuhn ve 2 diğer katkıda bulunanlar
En son July 11, 2024 tarihinde güncellendi
30 - 45 dakika
Orta
It is possible, though honestly rare, for the motor of a trimmer to fail for one reason or another. If changing the batteries does not restore functionality for this model, trying to replace the motor would be the next step.
Neye ihtiyacın var
Aletler
Daha fazlasını göster…
  1. Braun 5514 Motor Replacement, Motor: adım 1, 1 resimden 1.
    • Remove any attached trimmer heads by gripping and pulling away from the body.
  2. Braun 5514 Motor Replacement: adım 2, 3 resimden 1. Braun 5514 Motor Replacement: adım 2, 3 resimden 2. Braun 5514 Motor Replacement: adım 2, 3 resimden 3.
    • Insert an opening pick between the top plate and the grey separator.
    • Slide the opening pick around the perimeter of the plate to release the hidden clips.
  3. Braun 5514 Motor Replacement: adım 3, 1 resimden 1.
    • Remove the four 7mm Torx T6 screws attaching the grey plastic frame to the black plastic casing.
  4. Braun 5514 Motor Replacement: adım 4, 2 resimden 1. Braun 5514 Motor Replacement: adım 4, 2 resimden 2.
    • Use the opening pick to lift the grey frame from the black casing.
  5. Braun 5514 Motor Replacement: adım 5, 2 resimden 1. Braun 5514 Motor Replacement: adım 5, 2 resimden 2.
    • Remove the circuit board assembly from the frame.
  6. Braun 5514 Motor Replacement: adım 6, 1 resimden 1.
    • Pull the small black plastic piece out of the frame.
  7. Braun 5514 Motor Replacement: adım 7, 2 resimden 1. Braun 5514 Motor Replacement: adım 7, 2 resimden 2.
    • Desolder the wires attached to the motor.
    • Remember where the red and black wires attach in case the replacement motor doesn't have it labeled.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Andrew Kluckhuhn
1.079 İtibar
2 adet Kılavuz yazıldı
Ekip
IUPUI, Team S2-G2, Harley Summer 2018 IUPUI, Team S2-G2, Harley Summer 2018 üyesi
IUPUI-HARLEY-SU18S2G2
4 Üyeler
8 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 18
Son 30 gün: 46
Her zaman: 3,543
