Ana içeriğe geç
Braven BRV-X Button Module(s) Replacement
Neye ihtiyacın var
    1. Braven BRV-X Button Module(s) Replacement, Front Speaker Panel: adım 1, 1 resimden 1.
      • Remove four 1.1 cm outer screws in the outer shell using the Phillips #00 screwdriver.
      FixBot'a Sor
      Yorum Ekle
    2. Braven BRV-X Button Module(s) Replacement: adım 2, 1 resimden 1.
      • Remove four 1.3 cm inner screws in the outer shell using the 1.5mm Hex screwdriver.
      FixBot'a Sor
      Yorum Ekle
    3. Braven BRV-X Button Module(s) Replacement: adım 3, 1 resimden 1.
      • Gently remove the outer shell.
      FixBot'a Sor
      Yorum Ekle
    4. Braven BRV-X Button Module(s) Replacement: adım 4, 2 resimden 1. Braven BRV-X Button Module(s) Replacement: adım 4, 2 resimden 2.
      • Cut adhesive tape on both sides.
      FixBot'a Sor
      Yorum Ekle
    5. Braven BRV-X Button Module(s) Replacement: adım 5, 2 resimden 1. Braven BRV-X Button Module(s) Replacement: adım 5, 2 resimden 2.
      • Remove eighteen 0.9cm screws in the inner shell using the Phillips #00 screwdriver.
      FixBot'a Sor
      Yorum Ekle
    6. Braven BRV-X Button Module(s) Replacement: adım 6, 3 resimden 1. Braven BRV-X Button Module(s) Replacement: adım 6, 3 resimden 2. Braven BRV-X Button Module(s) Replacement: adım 6, 3 resimden 3.
      • Pry open the glued inner shell using a spudger around all sides of the shell.
      • Don't use too much pressure as that could cause damage to the plastic.
      FixBot'a Sor
      Yorum Ekle
    7. Braven BRV-X Button Module(s) Replacement: adım 7, 2 resimden 1. Braven BRV-X Button Module(s) Replacement: adım 7, 2 resimden 2.
      • Remove ten 0.7 cm screws in the front plate using the 1.5 mm Hex screwdriver.
      FixBot'a Sor
      Yorum Ekle
    8. Braven BRV-X Button Module(s) Replacement: adım 8, 2 resimden 1. Braven BRV-X Button Module(s) Replacement: adım 8, 2 resimden 2.
      • Use a spudger to open the front speaker plate.
      FixBot'a Sor
      Yorum Ekle
    9. Braven BRV-X Button Module(s) Replacement: adım 9, 1 resimden 1.
      • Remove three 1.0 cm screws from the battery unit.
      • It is recommended (but not required) to remove the battery.
      FixBot'a Sor
      Yorum Ekle
    10. Braven BRV-X Button Module(s) Replacement: adım 10, 2 resimden 1. Braven BRV-X Button Module(s) Replacement: adım 10, 2 resimden 2.
      • Disconnect the ribbon cable attached the main board.
      FixBot'a Sor
      Yorum Ekle
    11. Braven BRV-X Button Module(s) Replacement: adım 11, 3 resimden 1. Braven BRV-X Button Module(s) Replacement: adım 11, 3 resimden 2. Braven BRV-X Button Module(s) Replacement: adım 11, 3 resimden 3.
      • Pry open the second plate holding in the speaker using a spudger around all sides.
      • It is recommended to use a spudger to remove the heavily glued areas between the plates before prying.
      FixBot'a Sor
      Yorum Ekle
    12. Braven BRV-X Button Module(s) Replacement: adım 12, 3 resimden 1. Braven BRV-X Button Module(s) Replacement: adım 12, 3 resimden 2. Braven BRV-X Button Module(s) Replacement: adım 12, 3 resimden 3.
      • Cut the 20 gauge wires attached to the front IR sensor and two speaker wires.
      • Leave enough length on the wire to work with it afterwards.
      • Cut the 22 gauge wire attached in the corner.
      • Solder the new speaker plate during reassembly.
      • To properly solder and desolder connections, visit the How to Solder and Desolder Connections guide.
      FixBot'a Sor
      Yorum Ekle
    1. Braven BRV-X Button Module(s) Replacement, Button Module(s): adım 13, 2 resimden 1. Braven BRV-X Button Module(s) Replacement, Button Module(s): adım 13, 2 resimden 2.
      • Remove the ribbon cable attached to the main board.
      • Pull from the clip and not from the cable.
      FixBot'a Sor
      Yorum Ekle
    2. Braven BRV-X Button Module(s) Replacement: adım 14, 1 resimden 1.
      • Remove three 0.7 cm screws from the button module(s) using the Phillips #00 screwdriver.
      FixBot'a Sor
      Yorum Ekle
    3. Braven BRV-X Button Module(s) Replacement: adım 15, 1 resimden 1.
      • Gently lift the button module from the enclosure.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Trey Peterson
301 İtibar
2 adet Kılavuz yazıldı
Ekip
IUPUI, Team S1-G5, Harley Spring 2019 IUPUI, Team S1-G5, Harley Spring 2019 üyesi
IUPUI-HARLEY-S19S1G5
3 Üyeler
6 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 7
Son 30 gün: 37
Her zaman: 743
