Ana içeriğe geç
Braven BRV-X Front Speaker Panel Replacement
Neye ihtiyacın var
  1. Braven BRV-X Front Speaker Panel Replacement, Front Speaker Panel: adım 1, 1 resimden 1.
    • Remove four 1.1 cm outer screws in the outer shell using the Phillips #00 screwdriver.
  2. Braven BRV-X Front Speaker Panel Replacement: adım 2, 1 resimden 1.
    • Remove four 1.3 cm inner screws in the outer shell using the 1.5mm Hex screwdriver.
  3. Braven BRV-X Front Speaker Panel Replacement: adım 3, 1 resimden 1.
    • Gently remove the outer shell.
  4. Braven BRV-X Front Speaker Panel Replacement: adım 4, 2 resimden 1. Braven BRV-X Front Speaker Panel Replacement: adım 4, 2 resimden 2.
    • Cut adhesive tape on both sides.
  5. Braven BRV-X Front Speaker Panel Replacement: adım 5, 2 resimden 1. Braven BRV-X Front Speaker Panel Replacement: adım 5, 2 resimden 2.
    • Remove eighteen 0.9cm screws in the inner shell using the Phillips #00 screwdriver.
  6. Braven BRV-X Front Speaker Panel Replacement: adım 6, 3 resimden 1. Braven BRV-X Front Speaker Panel Replacement: adım 6, 3 resimden 2. Braven BRV-X Front Speaker Panel Replacement: adım 6, 3 resimden 3.
    • Pry open the glued inner shell using a spudger around all sides of the shell.
    • Don't use too much pressure as that could cause damage to the plastic.
  7. Braven BRV-X Front Speaker Panel Replacement: adım 7, 2 resimden 1. Braven BRV-X Front Speaker Panel Replacement: adım 7, 2 resimden 2.
    • Remove ten 0.7 cm screws in the front plate using the 1.5 mm Hex screwdriver.
  8. Braven BRV-X Front Speaker Panel Replacement: adım 8, 2 resimden 1. Braven BRV-X Front Speaker Panel Replacement: adım 8, 2 resimden 2.
    • Use a spudger to open the front speaker plate.
  9. Braven BRV-X Front Speaker Panel Replacement: adım 9, 1 resimden 1.
    • Remove three 1.0 cm screws from the battery unit.
    • It is recommended (but not required) to remove the battery.
  10. Braven BRV-X Front Speaker Panel Replacement: adım 10, 2 resimden 1. Braven BRV-X Front Speaker Panel Replacement: adım 10, 2 resimden 2.
    • Disconnect the ribbon cable attached the main board.
  11. Braven BRV-X Front Speaker Panel Replacement: adım 11, 3 resimden 1. Braven BRV-X Front Speaker Panel Replacement: adım 11, 3 resimden 2. Braven BRV-X Front Speaker Panel Replacement: adım 11, 3 resimden 3.
    • Pry open the second plate holding in the speaker using a spudger around all sides.
    • It is recommended to use a spudger to remove the heavily glued areas between the plates before prying.
  12. Braven BRV-X Front Speaker Panel Replacement: adım 12, 3 resimden 1. Braven BRV-X Front Speaker Panel Replacement: adım 12, 3 resimden 2. Braven BRV-X Front Speaker Panel Replacement: adım 12, 3 resimden 3.
    • Cut the 20 gauge wires attached to the front IR sensor and two speaker wires.
    • Leave enough length on the wire to work with it afterwards.
    • Cut the 22 gauge wire attached in the corner.
    • Solder the new speaker plate during reassembly.
    • To properly solder and desolder connections, visit the How to Solder and Desolder Connections guide.
Sonuç
Trey Peterson
301 İtibar
2 adet Kılavuz yazıldı
Ekip
IUPUI, Team S1-G5, Harley Spring 2019 IUPUI, Team S1-G5, Harley Spring 2019 üyesi
IUPUI-HARLEY-S19S1G5
3 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 1
Her zaman: 254
