Ana içeriğe geç
Breville BKC600XL On/Off Switch Replacement
Neye ihtiyacın var
  1. Breville BKC600XL On/Off Switch Replacement, Bottom Cover #1: adım 1, 3 resimden 1. Breville BKC600XL On/Off Switch Replacement, Bottom Cover #1: adım 1, 3 resimden 2. Breville BKC600XL On/Off Switch Replacement, Bottom Cover #1: adım 1, 3 resimden 3.
    • Use a Phillips #0 screwdriver to remove the following ten screws:
    • Four 18mm Phillips screws.
    • Four 9.75mm Phillips screws.
    • Two 8mm Phillips screws.
    • The cover will not remove entirely. Keep green ground wire attached to the cover.
  2. Breville BKC600XL On/Off Switch Replacement, Black Water Inlet: adım 2, 2 resimden 1. Breville BKC600XL On/Off Switch Replacement, Black Water Inlet: adım 2, 2 resimden 2.
    • Remove the two 14.5 Phillips screws.
    • Ensure that only the water inlet valve can be moved.
  3. Breville BKC600XL On/Off Switch Replacement, Bottom Cover #2: adım 3, 2 resimden 1. Breville BKC600XL On/Off Switch Replacement, Bottom Cover #2: adım 3, 2 resimden 2.
    • Use a Phillips #0 screwdriver to remove the following six screws:
    • Six 14.5mm Phillips screws.
  4. Breville BKC600XL On/Off Switch Replacement, Power Cord: adım 4, 2 resimden 1. Breville BKC600XL On/Off Switch Replacement, Power Cord: adım 4, 2 resimden 2.
    • Remove the power cord from the groove. (the black cord that leads into the green wire.)
    • This creates more slack in the wire to give you more room to work with.
    • DO NOT remove green wire from the cover its attached to.
  5. Breville BKC600XL On/Off Switch Replacement, On/Off Switch: adım 5, 1 resimden 1.
    • Carefully pull both the red and blue wires that covered at the tip.
    • Do not yank them out from the other end. Move them aside and out of the way.
  6. Breville BKC600XL On/Off Switch Replacement: adım 6, 1 resimden 1.
    • Carefully remove the On/Off Switch from its slot on the outside cover.
    • The wires for the switch need to be tied back into the wires that lead to the battery. If needed, use electrical tape.
    Thanks to this great post, I replaced my Breville BKC700XL On/Off Switch. The momentary switch is JR Products 12815 Black SPST Mini Mom-On/Off Switch, $8 on Amazon. https://www.amazon.com/dp/B002UC6QY0?psc...
    Now, my Breville single serve is like new. I almost ordered a new machine, then I found ifixit. Kudos to you guys.
    Boyd Gilbert - Yanıt
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Antonio
135 İtibar
6 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 1-3, Propen Fall 2012 Cal Poly, Team 1-3, Propen Fall 2012 üyesi
CPSU-PROPEN-F12S1G3
4 Üyeler
18 adet Kılavuz yazıldı
3Kılavuz Yorumları
Any source for the switch?
Mark Bell - Yanıt
This repair worked like a charm! Boyd Gilberts part number link was perfect....coffee machine is running great once again.
anthonypetric112 - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 25
Her zaman: 3,930
