Ana içeriğe geç
Brother MFC-9130CW Ink Cartridge Replacement
Kamaljot
Kamaljot ve 2 diğer katkıda bulunanlar
En son June 24, 2024 tarihinde güncellendi
4 - 7 dakika
Kolay
This step-by-step guide will walk you through the process of replacing the printer ink cartridges in your Brother MFC-9130CW printer. Over time, printers will run out of ink, affecting their performance. By following this guide, you can navigate through the steps of efficient ink cartridge replacement, ensuring a smooth printing experience.
Before starting the process, remember to press the power button to turn off the printer. It's essential to handle the printer components with care.
Neye ihtiyacın var
iFixit bu bağlantılar üzerinden satın aldığınızda komisyon kazanır.
  1. Brother MFC-9130CW Ink Cartridge Replacement, Ink Cartridge Replacement: adım 1, 1 resimden 1.
    • Press the power button on the printer for a couple of seconds to turn it off.
  2. Brother MFC-9130CW Ink Cartridge Replacement: adım 2, 2 resimden 1. Brother MFC-9130CW Ink Cartridge Replacement: adım 2, 2 resimden 2.
    • Press the latch beneath the paper output area and lift it to access the ink compartment.
  3. Brother MFC-9130CW Ink Cartridge Replacement: adım 3, 1 resimden 1.
    • Identify the specific ink color you wish to replace among the available cartridges in the ink compartment.
  4. Brother MFC-9130CW Ink Cartridge Replacement: adım 4, 2 resimden 1. Brother MFC-9130CW Ink Cartridge Replacement: adım 4, 2 resimden 2.
    • Pull each ink cartridge tray out of its slot using the center handle.
  5. Brother MFC-9130CW Ink Cartridge Replacement: adım 5, 2 resimden 1. Brother MFC-9130CW Ink Cartridge Replacement: adım 5, 2 resimden 2.
    • Place the new ink cartridge on a clean surface.
    • Release the orange cover, as shown on the photo.
    • To prevent making a mess, set a paper towel on the counter or table in case of a spill during the replacement process.
  6. Brother MFC-9130CW Ink Cartridge Replacement: adım 6, 2 resimden 1. Brother MFC-9130CW Ink Cartridge Replacement: adım 6, 2 resimden 2.
    • Place the cartridge in the tray.
    • Gently press down on the ink tray with your thumb.
    • You should hear a click, ensuring that the new ink cartridge is secure in its place.
  7. Brother MFC-9130CW Ink Cartridge Replacement: adım 7, 3 resimden 1. Brother MFC-9130CW Ink Cartridge Replacement: adım 7, 3 resimden 2. Brother MFC-9130CW Ink Cartridge Replacement: adım 7, 3 resimden 3.
    • Slide the ink tray back into its original position within the printer.
    • Make sure it is properly aligned and secure within the compartment.
    • Once the ink tray is secured, press the ink compartment latch with your thumb, and gently close the lid.
  8. Brother MFC-9130CW Ink Cartridge Replacement: adım 8, 1 resimden 1.
    • Press the power button for a couple of seconds to turn the printer back on.
    • Print a couple of test copies to ensure the toner cartridge replacement was a success.
Sonuç
To reassemble your device, follow these instructions in the given order.
Bir başkası bu kılavuzu tamamladı.
Kamaljot
184 İtibar
1 Kılavuz yazıldı
Ekip
1Rehber Yorum
One step is missing : release the orange cover.
Artefil - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 49
Her zaman: 312
