Ana içeriğe geç
Bush Pump Riser Main Slider Replacement
Neye ihtiyacın var
  1. Bush Pump Riser Main Slider Replacement, Head and Handle: adım 1, 2 resimden 1. Bush Pump Riser Main Slider Replacement, Head and Handle: adım 1, 2 resimden 2.
    • Test pump performance by pumping 40 strokes.
    • An effective pump should return at least 10 liters.
  2. Bush Pump Riser Main Slider Replacement: adım 2, 2 resimden 1. Bush Pump Riser Main Slider Replacement: adım 2, 2 resimden 2.
    • Remove the two pins connecting the handle to the slider.
  3. Bush Pump Riser Main Slider Replacement: adım 3, 2 resimden 1. Bush Pump Riser Main Slider Replacement: adım 3, 2 resimden 2.
    • Pull the two lever arms away from the slider.
  4. Bush Pump Riser Main Slider Replacement: adım 4, 2 resimden 1. Bush Pump Riser Main Slider Replacement: adım 4, 2 resimden 2.
    • Lift the two pins attaching the pump frame to the head and handle up, off of the pump frame.
  5. Bush Pump Riser Main Slider Replacement: adım 5, 3 resimden 1. Bush Pump Riser Main Slider Replacement: adım 5, 3 resimden 2. Bush Pump Riser Main Slider Replacement: adım 5, 3 resimden 3.
    • Throughout this step, make sure you support the handle and head with at least three hands.
    • Slide the bearing rod out of the head.
    • Inspect the bearing rod and head for any wear or tear.
  6. Bush Pump Riser Main Slider Replacement: adım 6, 1 resimden 1.
    • Remove the head and handle, and place them on a clean surface to prevent contamination.
  7. Bush Pump Riser Main Slider Replacement, Riser Main Slider: adım 7, 2 resimden 1. Bush Pump Riser Main Slider Replacement, Riser Main Slider: adım 7, 2 resimden 2.
    • Firmly lift the riser main slider with two hands.
    • Use caution not to drop the riser main, as this can damage the pump cylinder.
  8. Bush Pump Riser Main Slider Replacement: adım 8, 3 resimden 1. Bush Pump Riser Main Slider Replacement: adım 8, 3 resimden 2. Bush Pump Riser Main Slider Replacement: adım 8, 3 resimden 3.
    • Use a pipe wrench to fully loosen the above grade riser pipe.
  9. Bush Pump Riser Main Slider Replacement: adım 9, 3 resimden 1. Bush Pump Riser Main Slider Replacement: adım 9, 3 resimden 2. Bush Pump Riser Main Slider Replacement: adım 9, 3 resimden 3.
    • Lift the slider and riser main pipe.
    • Place a pump rod clamp around the rod, and tighten it securely against the pump rod.
    • Carefully lower the riser main and slider to allow it to rest on the rod clamp.
  10. Bush Pump Riser Main Slider Replacement: adım 10, 3 resimden 1. Bush Pump Riser Main Slider Replacement: adım 10, 3 resimden 2. Bush Pump Riser Main Slider Replacement: adım 10, 3 resimden 3.
    • Loosen and remove both the pump rod jam nut and pump rod nut on the top of the slider.
  11. Bush Pump Riser Main Slider Replacement: adım 11, 2 resimden 1. Bush Pump Riser Main Slider Replacement: adım 11, 2 resimden 2.
    • Remove the riser main slider, and inspect it for wear and tear.
    • Set the slider in a sanitary place to prevent contamination.
Sonuç
Jake Devincenzi
117.485 İtibar
57 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 2
Her zaman: 185
